1.B Series Front Tranny Mount $15
2.B Series Left Front Mount $15
3.B16 Rods (set of 4) $30
4.92-95 Civic Clutch Master Cylinder and Slave Cyl $30
5.92-95 Civic Brake Master Cylinder $15
6.B16 SiR II Fuel Injectors $25
7.B16 (99 SI) Intake Manifold $25
8.B18c (99 GSR) Fuel Injectors OBDII $25
9.B Series A/C Set Up (compressor/Bracket/Lines/) $100
10. 92 Civic Rack-in-Pinion with tie rods $30
11. 99 GSR Rack-in-Pinion with tie rods $50
12. B16 Crank (2 in All with less than 40k) $40ea
13. 99 GSR Hood Latch & Hinges $20
14. 94 LS Fuel Rail $20
15. B Series IAC Valve OBDI $20
16. B16 Block (BARE & NEEDS NO WORK) #1405573 $75
17. B16 Rear seal $15
18. B16 Oil Pump $25
19. B16 Water Pump $25
20. B18b Water Pump $25
21. 94 Accord Head Lamps (pair) $30
22. 92-95 Black outer Window Trim $20
23. 95 Civic Radio Trim $15
24. 92 Civic Hatch Wing (teal green) $35
25. 92 Civic Upper Control Arms $40
26. 94 Integra Upper Control Arms $40
27. OBD II OUTTER FUSE BOX (with all relays and fuses) $20
28. 98 Civic ECU (D16y8) $20
29. 89 Integra ECU (5Spd) $20
30.94 Integra Climate Control $20
***THESE ARE USED AUTO PARTS****
All Parts WORK & are in VERY GOOD Shape.
Please send all Questions and Parts Request to
[email protected]
I do not own a parts shop, I pick up these parts from Local Salvage Yards and list them here.
Thanks
