Results 1 to 4 of 4
Thread: Rb20det using Q45 MAF?
    IA Member redrockets13's Avatar
    Default Rb20det using Q45 MAF?
    does anybody run this set up?
    i have a q45 maf and tried to wire it up and set safc2 so it can run properly. Didnt work!
    anybody have the correct wiring diagram to wire up the q45? i know its prolly posted somewhere but i have been searching for hours and found nothing.
    also what input and output should i set the safc2 to use the maf?
    this would be very helpful and any tips or hints will be greatfully appreciated.
    Senior Member Krazykouki's Avatar
    Ball Ground
    I recommend you not using a Q45. Your RB20 WILL NEVER idle correctly again.
    Use a Z32 or go standalone.
    No Homo.
    BoogieBoogieHedgehog
    Woodstock, Ga
    how do you go standalone?
    cuz i hate MAF on turbo cars it just screws things up.
    is there any way to run the MAF in the charged air? after the turbo
    ============ViperBite ============
    ok cool thanks for the info man.
    i took my bros z32 maf it it runs so much better now.
