Results 1 to 4 of 4
Thread: LS VTEC Turbo or LS Turbo what should I do to build it and what kind of tubo?
    ALEX #1Beaver's Avatar
    Default LS VTEC Turbo or LS Turbo what should I do to build it and what kind of tubo?
    LS VTEC Turbocharged or LS Turbocharged what should I do to build it,what does building mean what comes with that job? What is porting and polish?
    What would be better to turbo and build an LS or LS Vtec set-up?
    What kind of turbo should I get?
    I want 200+HP before the turbo goes on and after the turbo if i can get 400 or more?
    I have someone selling a LS block and a GSR head for $200 each what should I get first, Can I find any other deals like this?
    Thanxs For The Help!!!! :confused:
    IA Member spoolinb18's Avatar
    Stn Mtn
    IMO, i wouldn't just buy the block and heat and go from there, its not that simple. i own a b18b1 turbo so speaking from expierence, if you dont have the money to do it all at the time of the install, i wouldn't do it until you have everything and can afford a good build so that it would run like it came from the factory boosted. how many lbs are you planning to run? if 400+ hp is your goal, is this going to be your daily driver? i would check teamintegra.net and do some research there, they have a lot of articles on this.
    Quote Originally Posted by hchbdx94
    Hwy 315
    replacing internal parts, strengthening weak areas such as bearings, and balancing moving parts
    refers to manifolds... porting (enlarging) polishing (polishing)
    depends on how many miles per gallon you're looking to get... to each his own
    depends on what guidlines of performance you are looking at. a standard t3 size would be hard at work around 2500 rpms, whereas a larger t4 would just be getting started. It all depends on the size of the exhaust and intake turbine blades. Garrett makes outstanding turbochargers.
    i have a friend with a 675hp civic...(terry @ Boostfed Racing) you can get any kind of performance you want if your pocketbook is big enough
    YES
    now go save your pennies
    [/URL]
    Jesus Christ is my Savior
    somewhere near ur mom...
    isn't this a all motor section?
