Thread: FS Bosch Fuel Pump & PLx wideband
    Privateer Racing!!
    Duluth,Ga
    Default FS Bosch Fuel Pump & PLx wideband
    The fuel pump is used and has about 200 miles on it!! Works perfect!!
    Asking $200
    Heres some details on it
    This is the popular Bosch Motorsports "044" fuel pump, as used by Japanese European & Australian tuner shops, JGTC cars, Touring cars, almost all WRC cars, and many more. Quite possibly, the most popular aftermarket fuel pump. Capable of providing 300 LPH free flow and 200 LPH at 5 bar (or 72.5 psi) for up to 685 BHP. In comparison, the Walbro 255 "high pressure" fuel pump can support 390 BHP Note: Values calculated at 12V, 3 bar (43.5 psi) base fuel pressure, 2 bar (29 psi) boost pressure, 1:1 fuel pressure regulator ratio. These are inline fuel pumps, we recommend they be installed between the factory (or another aftermarket) in-tank fuel pump, and the fuel rail. These may be installed in the fuel tank, but some custom fabrication will usually be required. In addition, feeding these inline pumps with another pump (in series), will boost the output of the Bosch 044 fuel pump even higher
    Now i have the PLX M-250, it does not incuded the gauge as it has broke
    asking $150.00
    Heres some info about that
    Affordable, accurate, compact, feature packed, and simple to use are only a few words that describe the PLX M-Series Wideband Oxygen Sensor Controllers. Designed in the heart of Silicon Valley, California with the highest technological standards, we bring you three wideband oxygen sensor controllers that meets the needs of every automotive tuner!
    The M-Series Wideband Oxygen Sensor Controllers are extremely simple to use and to setup. They do not require complicated sensor calibration procedures nor do they require any confusing software setup. Simply, connect the power wires to a 12V source, snap the sensor wire harness with the oxygen sensor and you're ready to start measuring your automobile's air/fuel ratio within minutes! PLX Devices widebands are guaranteed accurate to 0.1AFR with race proven technology which yields extremely fast reaction times.
    Key Features:
    • Works with standalone engine management systems
    • Accurate Air/Fuel Ratio <0.1, Fast Reaction
    • Advanced Sensor Self Calibration Circuitry. No manual calibration required.
    • Wideband LINEAR Analog Output (0-5V)
    • Narrowband Analog Output (0-1V)
    • Replace your stock Narrowband sensor
    • 32 MHz Advanced DSP Technology
    • Built in Resettable Fuse (No external fuse needed)
    • Sensor soft start circuitry, prolongs o2 sensor life
    • Compact and Professional Design
    • "Plug and Play" Installation
    • ISO 9002 Certified Assembly
    Kit Content:
    • M-Series Wideband Oxygen Sensor Controller unit.
    • Bosch wideband oxygen sensor for M-250/M-300.
    • 8 ft plug and play wire harness for connection between the M-Series Controller and the oxygen sensor.
    • 4 ft wires brought out from the M-Series Controller for connections to power and analog output signals.
    Attached Thumbnails Attached Thumbnails -plx250-jpg   -bosch-pump-jpg
