Thread: LS/VTEC problem
    Dec 2003
    Default LS/VTEC problem
    My friend just installed an ls/vtec in his 00 civic si and is having trouble. If he just presses the gas down it will start to rev then bogg down. He can just keep tapping the gas and it will rev up. Can someone help.
    WEST_SIDE
    . bad ecu maybe . any check engine light ?
    take it to a shop tog et it checked . if your friend cant diagnos the prob i dont think he'll be able to fix it
    Dec 2003
    No check engine light. He is planning to take it to a shop but I was hoping maybe it was something small like a vacuum line or something to that nature. He has had to replace his cat awhile ago because of his old b16 was smokin bad and cloged it but could this happen if the cat was clogged again.
    what ecu is he running? any cel?
    Dec 2003
    He has the stock 00 SI ecu, whatever that one is.
    LS/VTEC FTMFW!! SKUNK2GUY's Avatar
    lawrenceville
    g/l ls/vtec is a nice choice! if done right
    YEAH I LIKE TO PARTY!
    Ohio asshole.
    Quote Originally Posted by rickylsi
    It's entirely possible. Pull the exhaust off from the header and start it up! Same thing happened in my dads truck.
    ecu for 00 si=1.6 vtec
    ls/vtec=1.9 vtec
    what you're running right now is ecu for lower displacement and different timing maps. ls/vtecs almost always need to use a socketed/chipped and tuned ecu. sometimes you can get away with running a gsr ecu since they are same displacement...think of a ls/vtec as a gsr w/ more torque and less revs.
    let me know if you want a socketed/chipped ecu.
