Results 1 to 4 of 4
Thread: Code 20 : ELD
    Augusta, GA
    Default Code 20 : ELD
    I'm getting a Code 20, which is the ELD, electronic load detector. Where the hell is that..And how to fix it.? I could easily disable the ELD when i chip my ECU, but I want to fix it, rather than "bypass" it..Let me know if you got any ideas..Thanks..
    Bender A. Rodriguez
    Macon
    Its in the fuse box under the hood. If you email me at [email protected] I can email you back the OEM repair manual stuff for how to test and replace it. It won't really do anything if you don't fix it but I don't think you can bypass it with a tuned computer but I'm not sure.
    Ryan Reynolds
    do what ryan suggested, but if you can't fix it and depending on what program you're using you can disable it and forget it if necessary.
    Alpharetta/Duluth
    Check all of your fuses and all of your grounds (underhood, under dash, ecu)... then consider replacing the underhood fusebox. Goodluck
