Results 1 to 3 of 3
Thread: Turbo Upgrade... Need Advice...
    Unknown
    Default Turbo Upgrade... Need Advice...
    Ok I have a D series civic with a Greddy turbo kit on it... specs of the turbo I am not to sure of... the best I can guess is that its a TD04H-15g turbo... and I think the turbo itself just died... what my question is... Is if I upgrade the turbo manifold to either a t25/28 flange or a t3/t4 flange and get a matching turbo with those flanges ... whats the possibility that i can still use the same IC piping and what not... Basically... can I use everything on there now and just upgrade the manifold and turbo itself... ? Thanks for your assistance and help, Oh and suggestions with what route I should go would be great.... I am planning on swapping the kit onto a built D series later on... so anything that could be used later on also would be great! Thanks again!
    you will more than likely need to replace manifold, turbo, downpipe, and possibly the charge pipe from turbo to fmic. the existing downpipe and chargepipe may be able to be kept with some modifications.
    Certified Gearhead miro_gt's Avatar
    I have a 15G turbo rebuild kit that I bought some time ago, and ended up using only one seal from it, which I found later and put back in the kit, so it's complete again. I'm selling it for 50 bux ... pm me if you want it.
    best way IMO - fix your turbo, cause that's gonna be the cheapest way . When you build the engine up, then sell the whole kit, and piece together a new bigger one
