Thread: ka24de head issue
    Acworth
    Default ka24de head issue
    Hey guys ive got a slight concern
    Ive been driving my ka-t for about a week now and i haven't been driving it to hard since my clutch is slipping.But i thought i had a loose Bolt and washer on my exhaust or my throw out bearing was dying.. Here is the issue when i rev the engine to 3000ish rpm or when gearing down for a stop i hear the chatter and now it sounds more like its coming from the head..So i was wondering if anyone had any insight on the issue its a ticking chatter and it also vibrates the engine a bit when it makes the noise but its on when rpms are around 2200 to 2800 and only when there falling.. Kinda strange to me i dunno..
    Henry Co.
    i had that same problem, then it stopped. it was a rainy night, and as soon as boost kicked in i would jump to redline, i thought it was my clutch but it might have been my tires losing traction...which by the way is fucking sick!!
    Acworth
    Quote Originally Posted by JJ Alfano
    See that why i dont think its my valves is becuase im making 250whp at 6 psi if i was having loose valves i dont think it would be running and idleing well i dont even get black smoke.. just an odd smell i think its all the new parts breaking in but im really concerned out this valve/ head noise.
    My Spoon Is Too Big! Flip's Avatar
    The timing chain guides tend to make noise comin from the head...
    Acworth
    Quote Originally Posted by Flip
    But only when revs are coming down? and is there any fix for it or do i just need to ignore it?
    Norcross
    The timing chain guide that tends to make the most noise is right at the top when you take off the valve cover. The chain runs right under it. Just take it off if it is not already removed. See if that helps any.
    Senior Member babowc's Avatar
    one question..
    do our (ka24de) motors use hydraulic lifters?
    no, right?
    iirc.. sr and kaE uses the hydraulic lifters..
    Acworth
    Quote Originally Posted by babowc
    one question..
    no, right?
    Perhaps im missing how this comment helps my issue.. Im not really sure what to do at this point i cant find time to take it to a shop to take a look at it. I really dont want to pull the head to have it rebuilt. And im not going to remove parts that nissan put in there to get rid of the noise. Im sure there has to be some way i can fix this problem or there is a shop open on sunday.
