Thread: local rb25 help?
    Default local rb25 help?
    First off i am not looking for anyone's opinion on what motor will be better for my car, i am just looking to see who has motor mounts and drive shafts to put an rb25 in an s14.
    Thank You
    About to approach beast mode
    Bender A. Rodriguez
    Macon
    Top Hat. I prefer they're mounts to the McKinney setup. They usually keep a set ready.
    Ryan Reynolds
    thank you, i looked them up on the web and will be visiting them soon since they are so close
    Senior Member Krazykouki's Avatar
    Ball Ground
    www.tophatperformance.com
    further details just PM me.
    No Homo.
    Bender A. Rodriguez
    Macon
    see, i'm not the only one. They make some good shit over there.
    Ryan Reynolds
    Ball Ground
    Quote Originally Posted by Cool Cat Racing
    Plans for lots of new stuff too..
    No Homo.
    Classic Celica
    Orlando, FL.
    ^agreed.
    '84 Toyota Celica GT :boobies:
    Ball Ground
    check pix section...
    No Homo.
    Banned Stopsnitchin's Avatar
    a friend of mine got a motor thru them and installed by them. after seeing the bullshit they pulled i'll never go there. good luck. www.lethalinjectiontuning.com
    rb20 s13 in progress driftjdm's Avatar
    atlanta
    Quote Originally Posted by Stopsnitchin
    what did they do that was so bad
    ..::|i smell tire smoke|::..
    (oo=[][]=oo) slowrolla97's Avatar
    Marietta GA
    Ok I havnt got around to calling them yet but can someone answer my question..
    Can you use your stock drive shaft when using the top hat rb25 mounts? I know they make a DP that will clear the stearing linkage and there mounts are the cheapest around by far. Some one said it and i didnt know if it was a rumor or it was true.
    240atlanta.com
    Broke sullen's Avatar
    Acworth
    i've never done a rb swap, but im gonna spring and say it probably won't work. the addition of the extra 2 cylinders means the motor doesn't sit in the same positioning. from what i've heard about the rb swaps, some firewall modification has to be done. if you actually do have to modify the firewall, that means the motor sits further back. if the motor if further back than the stock motor, it will translate to a different length driveshaft. www.driveshaftshop.com
