Results 1 to 18 of 18
Thread: not passing emissions
    boost wanted GermanMuscle's Avatar
    Duluth, GA
    Default not passing emissions
    i have a 90 integra that didnt pass emissions this morning. the NOx is 1540 and 1370 is allowed. it has to do with the exhaust gasses that all i know.
    how can i get to it to pass the emissions? i was gonna use this as a excuse to get an exhaust and do a swap but i just dont have the money.
    i also need this car to pass ASAP
    90 Integra....Sold
    96 Jetta VR6...current money pit
    Duluth, GA
    someone must know something
    90 Integra....Sold
    your moms house
    register it in barrow while you still can
    FUCK B&D COMMUNICATIONS!
    Duluth, GA
    dont i have to live there or own a property out there?
    90 Integra....Sold
    Duluth, GA
    where is barrow county anyways?
    90 Integra....Sold
    your moms house
    its a blown headgasket...ill give you $250 for the car
    Gainesville
    register in hall county or find some one in your area that can be conviced to help you pass emissions
    Hampton, Ga
    catalytic convertor
    Gainesville
    i ahve one a high flow one that i bought from ebay.. don't need one where i live tho, well not yet anyways.. no sure if mine would pass or not.. i jknow it runs clean tho. no strong smell or smoke well it floods now cause i need new spark plugs and wires and a new o2 sensor
    Duluth, GA
    Quote Originally Posted by Steveo
    i would still keep the car and just have to wait awhile to do the swap
    actually i think i found out where the problem is, its in the egr system. i did some reading and found that the egr is to reduce the oxides of nitrogen emissions (NOx)
    the catalyic converter is for the hydrocarbons (HC), carbon monoxide (CO) and oxides of nitrogen (NOx) gasses
    most commonly for the NOx its the egr but the cat converter is a possibility
    90 Integra....Sold
    Duluth, GA
    if i want to register my car in a county that doesnt require emissions dont i have to own a property there?
    90 Integra....Sold
    your moms house
    Quote Originally Posted by GermanMuscle
    JESUS FUCKING CHRIST!! SOMEONE ON IA ACTUALLY DID SOME RESEARCH ON THEIR OWN!! THIS IS A FIRST!
    LAWRENCEVILLE
    But one problem integras dont have a egr system! it did not fail that bad what has worked for me before I take the the test I would retard the timing a bit.
    Hella stock member!
    Duluth, GA
    well my dad is the one that took it to emissions today again and the guy told him to look into the egr system so i looked in my factory service manual where i found that info
    STEVEO: i tryed searching before i posted but it was just too much out there about emissions that didnt have to do with NOx, YOUR JUST MAD CAUSE YOU CANT HAVE MY CAR and your the one that talked me into keeping the car
    EDIT: it turns out that only the automatics have the egr system. so the only other option is the cat. converter. at least i know what the problem is
    90 Integra....Sold
    *No_Pissed-ons!* chava_rx7's Avatar
    Braselton
    make sure you do a complete tune-up this will help since your parts are brand new. but make sure you check your oxigen sensor, cuz if its bad this may cause ur ecu to fuck with the air-fule ratio and you will not get the best combustion and ur car will not pass emmissions even if everything ells in the car is brand new (spark plugs wires pcv egr basically all ur emmission shit) this is one of the thing a lot of people forget to check and if it is the problem it will pass emmissions no problem
    Quote:
    Boy, your better off doing drugs because there isn't any rehab or therapy for rotaries or boost.
    LAWRENCEVILLE
    did not know that i would still just retard the timing for the test
    Hella stock member!
    Gainesville
    Quote Originally Posted by chava_rx7
    what's oxigen?
    Duluth, GA
    i replaced the cat converter this weekend and it passed...well lets just say i put a cat in, it was just the housing with nothing on the inside. that just kinda causes the car to fail the emissions
    thx for all your help guys
    90 Integra....Sold
