Results 1 to 5 of 5
Thread: 2 amps, 1 Four Channel, 1 Two channels...Wiring the power?
    Default 2 amps, 1 Four Channel, 1 Two channels...Wiring the power?
    Hey, im dan and i got a Q.
    I live in gwinnett and im eyein up my first car n pretty likely to get the car i want so i thinking of gettin a gps and a soundsystem for it.
    i know bout frequencys n ohms n all the good stuff but i dont know crap about wiring...
    If you have a 600w 4 channel amp powering all four speaker on a 850max Watt powerkit... AND also have a 2 channel 200w amp for ur sub how do u connect them to the headunit and to power?.
    i know for the head unit ders connection in the back hopefully, n thats were u get L,LR R,RR but were do u get the sub? or is it already der.
    Can u make a 200w amp share witha 600w amp the power connection if it maxs out at 850?
    help help
    OH PS neone know ne shops that are cheaper but as good or better as circut citys roadshop?
    POWERKIT intending to use
    Senior Member | IA Veteran DJ XtRaKŠ's Avatar
    Apr 2001
    Roswell
    you will need to get a multi amp power ket like this one:
    http://www.circuitcity.com/ssm/Tsuna...oductDetail.do
    or you can just get some distrubtion blocks and use those to get the power to the 2 amps.
    as far as getting the audio from the headunit you will need 3 sets of pre-outs from your headunit (front, rear, and sub). you will then need a set of 4-channel rcas and a set of 2 channel rcas.
    kthnksbye.
    IA OG
    Hiram, GA
    www.bcae1.com
    read up on there, it will answer all your questions.
    Quote Originally Posted by DJ XtRaKŠ
    kthnksbye.
    ah! thank you for the link to that kit man
    BanginJimmy: the site is useful thnxs
    Mystery Solved, id say this should get post the year award
    thanks guys
    StreetDimensionzInstaller db_bogdan's Avatar
    Marietta, GA
    what u need is ... 1 distribuitor block (for power)... 2 ground wires... and just conect both remote wires together!!! it`s easy
    2003 Mazda 6 MUHAHAHA !!!
    1991 CRX HF IS deceased.....
