Thread: ABS brake conversion
    00 EK B18B1 boostedy8's Avatar
    Gainesville
    Default ABS brake conversion
    Just wondering if a ABS brake system out of an integra will work in my 2000 ex coupe? I think that the system is out of a 96-97 LS.
    Gainesville
    LAWRENCEVILLE
    no it will not! the lines are diffrent and its a lot of labor to do!
    Hella stock member!
    v2.0 IndianStig's Avatar
    Sep 2004
    Gwinnett County
    I don't see why you want ABS......as long as you have 4wdisc i think your fine..
    Gainesville
    Cause i am starting to use my car at track events and i want abs cause i have a problem on the street with my current brake set up with power slot plus rotors (12.1" inch rotors) and just the drum brakes, it will lock up the left front wheel when i try to do any hard stoping. I dont want to be at the track and doing 100+ going into a turn and lock up the front wheels. I dont mind doing the work to convert it to abs cause it would be worth it in the end. Don't some EK civics come with abs brakes. I know that the EG's came with it if you had an ex.
    LS/VTEC FTMFW!! SKUNK2GUY's Avatar
    lawrenceville
    yea pry like a 4 door ex came with it but no sure g/l yo
    YEAH I LIKE TO PARTY!
    Gainesville
    any body else have any comments as to what i should do.
