$325 ABO for the two 12' Alpine type R subs
Alpine Type-R SWR-1242D 12 inch Car Subwoofer
Features:
Peak Power Handling 1500 Watt
Nominal Power Handling 500 Watt
Frequency Respond 24 Hz - 500 Hz
Sensitivity 87 dB
Impedance 4 ohm
Specifications
High Excursion Tapered Half-Roll Surround
Aluminum Coated Dust Cap
Mirrored Progressive with Perimeter Venting
Frequency Response: 26Hz 1kHz
Dual Voice Coil Design
Extra Rigid Steel Frame
Heavy-Duty 8GA Push Terminals
$35 ABO for the one 15' rockford sub
SpecificationsNumber of Channels1Watts per Ohm1 x 500Watts per Channel 2 Ohm1 x 1000Bridged Mono at 4 Ohmn/aModule Ports2-Accessory![]()
$420 ABO for the amp
Features
- Regulated Transitional Class D Technology
- Fully Regulated PWM Power Supply
- Complimentary MOSFET Design
- Defeatable Balanced Input
- Adjustable Input Sensitivity
- 24dB per octave variable Low Pass Crossover
- RCA Outputs with 24dB/Oct Crossover
- Phase Inversion
- 1/0 gauge Power and Ground Connectors
- Dual Speed Fan Circuit
If you buy both the Xtant amp and the two 12 alpine type r, I will sell them together for $$650
Call for Jon (770)-309-7256
