Results 1 to 16 of 16
Thread: air/fuel gauge?????????????
    Where Am I
    Default PLEASE HELP ME !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Ok just hooked up an air/fuel gauge on my civic and I can't figure out why the check engine light is now on and I can't make it go off, I've reset the battery a couple of times but after a couple of seconds it will come on again. I don't know if I hooked it up wrong or what and the car is sputtering a little bit... Ok their are four wires on the O2 sensor- 2 black, 1 white, and 1 green. I have it hooked up to the white one cause that was the only one that actually made the gauge move... So is this the right wire has anyone done one of these on a civic or something like that. PLEASE HELP
    SCROLL DOWN TO MY NEW PROBLEM
    Where Am I
    I really need to know if I hooked it up to the right wire. I know there is a signal, signal ground, heater voltage, and heater ground just can't find anywere what color they are.
    Down again
    Where Am I
    Ok went and got the car scanned today and it said bad heater wire on the O2 sensor so I replace it and its still throwing the code and for some reason now my seedometer doesn't work either and when it does it bounce back a fourth sometimes it tach's out at like 140-150 Mph, just when I was pulling in my driveway. Do the O2 sensor and the speed sensor have something in common or something to make it do these things at the same time... Some one please help me. PLEASE..........
    Woodstock, Ga
    Did you clear the code from the ecu? Do you still have the gauge hooked up?
    Where Am I
    Yes I cleared it from the ECU and it still comes back and no the gauge isn't still hooked up, I read somewere that their is a relay that could have blown but I have no idea were its at.... PLEASE HELP ME
    Gainesville
    soundslike something got fucked up with the ecu.. but not sure.. ask mike
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    wtf what kind of air/fuel guage is it? 4 wires?
    all the ones i've ever had were 3 wire... purple to 02, ground and +12
    thats odd
    maybe this will help:
    if ur + and ground are hooked up right and everything else isnt hooked up... it should read max rich...
    Gainesville
    whenever i hooked mine up i had a purple a brown and a white. i got a 96 civic with a d16y7 tho
    IA Juinor Member Mr_S13®'s Avatar
    Cumming, Ga
    Alright, so your saying you have a 4 wire 02. The 2 blacks are the heater power and ground. The green is the signal and the white is the signal ground. the purple wire from your gauge...assuming its autometer...needs to attach to the green wire. The gauge will not read until the sensor reaches 600 degrees farenheit. So if you were hooking it up and cranking it and shutting it back off your not gonna get a result. As far as the issues your experiencing, it may be a result of grounding out the sensor and damaging something in your ecu. The only way to check that is to pull out your ecu, and smell it. If you smell a burnt smell...kinda like a blown speaker...then pull the cover off and look for black spots on the backside of the board. Otherwise, if you completely cut your o2 off the rewired it you may have your heater wires reversed. And also check your connections. Hope this helps! Sorry for the lengthy post!
    [SIGPIC]
    Gainesville
    good info... props
    Where Am I
    Quote Originally Posted by EgLover119
    OK thanks I need to go and the ECU then I hope thats not the problem. and I know I didn't get the wires mixed up because it wasn't universal O2 is was just a plug in one so IDK. But thank u anyone else have any ideas will let u know if the ECU is the problem.
    - Oh if I put in a GSR ECU in the EX civic would this tell me if the ECU in the civic is bad or will that just not make it run right either. Just so I can see if thats the problem rather then getting a nother ECU from a D16.....
    Ohio asshole.
    What year is it? I know in my 96 civic. When i first got it the fuse that makes the speedo work, and turns the alt. on to charge the car was blown. Caused my speedo to randomly jump. Replaced the fuse, never had a problem with it after that. While it was blown..the car would still run, but barely charge the battery enough that it would keep running. After i replaced 3 batteries, all the power/ground wires to bigger wire, and an altenator, i found out it was a fuse...300 bucks later.
    Where Am I
    Fixed it thanks to jmmx258, Thanks again man...
    everywhere & nowhere
    ^^ Post ur fix online to help the community. Also ur posts were hard to follow. In ur final post (b4 the mods lock it), post year, make, model, engine, ECU, and what product u were installing. Also post what OBD u are.
    Ohio asshole.
    I dont know the specs on his car. I do know that it was the fuse in the box under the dash for the Alt. Speedo, and something else i cant recall. Its like a 7 Amp or 7.5 amp fuse. I'm assuming its a 96-00 civic though. Thats what i was having the same troubles in.
    Where Am I
    1997 Honda Civic Ex D16y8, it was the Altenator fuse under the dash
