Results 1 to 11 of 11
Thread: help me build 8" sub box
    Certified Gearhead dp32185's Avatar
    Default help me build 8" sub box
    im trying to make a box out of mdf for ONE 8" sub. any of you know what dimensions would be the best?
    Little Red Ridin Hood
    In My House
    what kind of sub is it?
    MROZ10
    ^^^ exactly. The box will be determined by the theile-small parameters of the subwoofer. Go to the manu's website or check the manual and find out what the recommended air space is. The shape of the box doesn't matter (as long as it's not perfectly square) as long as the internal airspace is correct. To calculate air space of an enclosure you want to build, multiply the w x d x h and divide by 1728. This will give you the air space in cubic feet. Hope this helps.
    IA MEMBER YokotaS13's Avatar
    saudi arabia
    unless your messing with fiberglass and your all fucked up lol. It took me forever to calculate my airspace, but i just made it by like .01 or somethign liek that. After thatn you cut the boards and nail/wood glue it together
    Formerly Spyder Man
    Buford, Ga
    Quote Originally Posted by tsispyder
    nail?
    :boobies:
    saudi arabia
    screws are overrated, get an air nail gun, line the edges with wood glue, it works fine. My audio guy does the same thing. And ive never had a box spring a leak in 4 years. And he has built me 5 or 6 fiberglass boxes, along wiht the 1st place stereo install at nopi last year, and 1st and second int ehir classes escalade and tahoe at nopi as well.
    Formerly Spyder Man
    Buford, Ga
    hmm. you must have some special nails, every time i use them i have blown the box apart... then again it alll depends what speakers and what box design. i have no problem using nails to get a box in shape. however using them to actually hold it together is not something i would recommend.
    btw fiberglass is comepletly different...
    :boobies:
    saudi arabia
    yeah i know glass is different, iw as just pointing out that it would make it completely different.
    As far as the nail thing, make sur eyou use a good wood glue, thats what really holds it together honestly. THe nails just hold it until it dries.
    back on topic, it should only take you a few hours to make it, its not an in depth project unless youw ant to go bandpass or whatever, but its jut a box, dont look too far into it.
    Formerly Spyder Man
    Buford, Ga
    build a transmission line box for it!
    (only real audio nerds know what this is lol)
    :boobies:
    this is what i have:
    http://www.mbquart.com/2003/en_US/pr...=RWE+202%2F204
    so i learned something new already...using wood glue
    Augusta Georgia
    www.edesignaudio.com/boxbuilder go build it yourself.
