Thread: obd0 to obd1?
    the county
    Default obd0 to obd1?
    ok i'm about to purchase a 88-91 zc nonvtec motor and i need to know if i can use my d15 harness on it (as far as sensors and what not).
    the county
    someone has got to know this.
    will my obd1 harness work on a obd0 motor?
    yes it will work but as far as the distributor it will not plug up and you will have to get obd1 injectors to fit your injector clip and will not have to add a resistor box or clip it and use the obd0 injector clips and you will have to add a resistor box if you are planning on using the injector that came with that motor.
    no you cant use your obd1 harness on the engine. use the original harness from the car. if your car is a DX youll need to do the mpfi conversion as well, but you still need to modify the car's stock 1.5 harness.
    well i thought they meant obd0 motor in a obd1 car.
    oh my bad, if they are putting it into a obd1 car then they need to use their obd1 harness.
