Results 1 to 19 of 19
Thread: b16a help
    random guy's pops!
    random guy's moms cornhole!
    Default b16a help
    could someone please give me a list of stuff i need to get for my motor b4 i drop it in my car , ie , timin belt , plugs , and if its not too much trouble could you please put brands and any other specific specs i would need ! thanx!!!
    dnwp
    WEST_SIDE
    you mean parts to drop it into the dx.
    your moms house
    ngk plugs only, OEM timing belt and do a water pump while youre there too...i would also do a HG while its outtoo but thats just me
    FUCK B&D COMMUNICATIONS!
    random guy's pops!
    i am orderin the mounts today , i am talkin about any kind of preventive maintenance , and anything that should be swapped out while the motor is out of the car , i know it is easier to do the timing belt when it is out of the car , that kind of stuff
    dnwp
    your moms house
    Quote Originally Posted by EF_SCOTSMAN
    rear main, oil pan gasket, valve cover gasket, hell do valvve seals too lol...i mean if you got the time and some extra money to do it with...itll seem like nickle and diming you but itll be worth it in the long run
    WEST_SIDE
    e erytime i did a swap it was TB, WP, PLugs & wires, thermos, oil pump(might not be needed but did it anyway), cap and rotor. a Head gasket would be good too.
    when the engine was running FI clean up, and ran it for about 5 mintues with 3 quarts of engines oil and 1 quart of trans fliud, drain that and fill it back up with motor oil of your choice.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    All the seals comes from a 99 civic si or del sol vtec. The clutch is a 90-91 da. Oh yeah rear main seal in 90-91 da too. Starter, alternator, cap and rotor 90-92 da.
    DC5-R
    Gwinett
    well lets start off with what your b16 came out of, I'm assuming its OBD-0 and came for a EF correct? If that is the case and you have all the necessary parts like half shaft, axles, mounts, shift linkage, etc. Then all you really need is timing belt and water pump for freshin up the motor before droppin it (recommended but not mandatory).
    Ball park (depends on your connect)
    timing belt + water pump (OEM) - $150 or so
    Spark plugs (NGK) - $10-20
    Ignition wires - (NGK) - $40
    Cap, button, etc - $20-30
    random guy's pops!
    thanx fellas , this is the exact shit i was lookin for! i repped all that i could!
    dnwp
    random guy's pops!
    are 8.5 mm wires too big?
    dnwp
    WEST_SIDE
    seen the other pics that its a 5xxxxxx series came from an SIr (ef)
    edited*** ***
    im sliping like a NOOB
    WEST_SIDE
    also if you need the MPFI i have the box you'll to convert from Dual port
    random guy's pops!
    already been converted , thanx though
    dnwp
    WEST_SIDE
    sweet man . take some pic. when is hte swap going down
    random guy's pops!
    there will be mad pics taken , i am startin tomorrow , pullin out the old motor , then cleanin and paintin the engine bay ( while i wait for my mounts) , i hope for it to be in and runnin by next weekend!
    dnwp
    random guy's pops!
    anyone???????
    dnwp
    your moms house
    i honestly have no idea about that part
    DC5-R
    Gwinett
    no you should be fine, but ignition wires aren't goin to make a big difference, the blue NGK's are the best bet...why? Because OEM and NGK share the same characteristics, unlike BIGGER wires, these are CONSISTANT, where as bigger are not. Get it? And where are my reps at! lol, j/k
    random guy's pops!
    only reason i asked is cause i just picked up a nother dizzy and it came with practically new wires , they are 8.5mm , i think they are called magstars???? i could be wrong
    dnwp
