Thread: 02 passat gls 1.8t 5spd
    Default 02 passat gls 1.8t 5spd
    does anyone know where the fuse box is ? reps to the person that knows!
    boost wanted GermanMuscle's Avatar
    Duluth, GA
    did you check under the hood by the battery? or under the dash on the drivers side
    Side of the dash when you open the door. You can pop the flap open with your key, and all the fuses face you, no going under the dash or anything. Gimme my reps.
    ***Lotus Elise***
    BlackWatchRacing
    You must spread some Reputation around before giving it to Kyle again.
    i did my best ill rep u as soon as i can thanks man
    Say What??? thegreatfnr's Avatar
    Quote Originally Posted by drmcivicsi
    Open drivers door and on the end of the dash panel is a cover, just pry it off with a screwdriver. Thats it.
    edit: kyle beat me to it
    Lee
    2005 C55 AMG
    durtydubs
    No problem. What did you need to do?
    ***Lotus Elise***
    BlackWatchRacing
    nothing on my brothers dash works so i was thinking it had to be a fuse somewhere
    Did that solve the issue?
    Lee
    2005 C55 AMG
    durtydubs
    IA KING
    here is step by step:
    1) open driverside door
    2) hit the gas door button
    3) walk around the car and open up the the gas door
    4) unscrew the gas cap and insert your penis into the hole
    5) once you have done that you should be able to find the fuse box; if not you have a small penis
    NYC/ATL
    Quote Originally Posted by admin
    No it's just a VW...
    Smyrna
    Otherwise infamous for dreadful and exspensive electrical problems.
