Results 1 to 21 of 21
Thread: car shaking
    VTEC INSIDE
    clayton county
    Default car shaking
    i was wondering if anyone owning a 1999-2000 civic si has had a problem with the car shaking when you hit 50 and suddenly just stop shaking once you hit 60...just trying to figure what is causing this because it is very annoying...any help will be thankful...
    Super Dave Z U L8R's Avatar
    Roswell
    balance your tires
    ..and your point?? Whitebandit's Avatar
    Albany/road less traveled.
    Quote Originally Posted by Z U L8R
    balance your tires
    He means balance your rims...
    Oct 2003
    yea balance them
    or maybe ur car is just cold, put a blanket on it
    civsi
    atlanta ga
    yeah, balance your tires, should clear that right up.
    I LOVE MY HONDA
    San Diego, CA
    Tires bad, bad alignment, or bad balance. Just go to a firestone and tell them you want a lifetime of alignments. It's like 90$, but you've got unlimited visits. As someone who's done much work to their car...you can take full advantage of this... Can't even count how much I've been there for that.
    JDMadness ==> EvasiveEF9
    Maybe it saw an NSX and had a cargasm?
    San Diego, CA
    I wish I could have a gasm that lasted for days...
    Quote Originally Posted by JokerTypeR
    i've given them that lasted days
    San Diego, CA
    Uh...my number is 404.45....
    uh, i'm a dude fool.
    San Diego, CA
    An orgasm that lasts for days just MIGHT be worth it, LoL
    jk jk. All in good humor.
    PEENGONE Hektik's Avatar
    eeeeeeewwwwww youre naaasssssstyyy ...lol....
    i would definately go with the alignment or tire wear. i know i have pretty bad camber wear on my tires and when i hit 80 the car starts to shake a bit
    errr, dahlonega IS getting up there near tallulah gorge & chattooga river... "squeel like a pig"
    San Diego, CA
    Yeah...we call those people "Nuggets" (in relation to a gold-nugget...what dahlonega's famous for...)
    I am a nugget...
    San Diego, CA
    I am a nugget...
    AHHHHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!
    Roswell
    alignment will cause the car to wander left or right not shake......unless you have some super noticable serious toe out. tires are just out of balance. the reason you need to balance tires after they've already been balanced before is because the tire over time spins on the rim. therefore the rubber's not lined up with the rim in the same place
    Ballin on a budget
    Alpharetta, GA
    check into your axles/cv joints as well. I'm having the same issue in my TL and we have a few members on acurazine with the problem as well. A few of them have replaced their axles and the problem went away. Is it just under acceleration or when you let off the gas too?
    \m/>_<\m/ dorin48's Avatar
    Canton
    Also any misalignment in the suspension that goes unattended can cause the tires to cup and such. So dont wait too long or you will shake no matter what
    look on the bright side its like a freeee massage seat yo
