Page 1 of 5 12345 LastLast
Results 1 to 40 of 182
Thread: FS/FT-1986 SuperCharged MR2/LSD/Sunroof/Upgrades
    BLANK LongShot's Avatar
    Knoxville, Tn
    Default FS/FT-1986 SuperCharged MR2/LSD/Sunroof/Upgrades
    Ok tell you what $5,000 thats what I paid for it and thats as low as I am going.
    Now to the good stuff. I will be quoting Bill(previous owner) a lot here
    1986 with 155K on the chassis. PW, PDL. Had a Levin Supercharged engine/LSD tranny transplant a couple of years back. Runs great!!!
    Suspension = Suspension Techniques F/R anti-sway bars, TwosRUs front endlinks, Tokico Illumina shocks, Eibach springs, TRD bushings, steering rack bushing changed, inner and outer tie rods, new CV boots.
    Brakes = Just rebuilt all four calipers. Fresh pads. Speedbleeders installed. Master Cylinder rebuilt. Slotted rotors.
    Body = '89 Plumley mod spoiler, clear light mods on the 87+ tails, custom "PapaL" vented frunk lid, SC engine lid, Toysport front (small crack in center), '87+ side vent, shaved antenna, custom paint, tinted windows.
    Engine/tranny = 4AGZE with oversized (170mm) pulley. SPAL fan on intercooler. LSD tranny. Brass shifter cable bushings. Exhaust is a TRD header married to a JanSpeed exhaust, AEM adjustable cam gears, Kirk's motormount inserts, and GM Syncromesh in the tranny, eManage.
    Interior = '00 Spyder fabric seats, Kenwood head unit, Bazooka 8" sub, 4x6 Blaupunkt speakers in doors, Memphis Audios in the front. Custom embroidered armrest pad. Momo leather steering wheel. JonO Shortshifter kit with RSe plate, TwosRUs shift knob. Lots of little stuff done, like installing 87+ gauges and glovebox lid lock.
    Misc = Battery relocation mod. TwosRUs engine lid lift and trunk lift. SSR Comp wheels in 15" wrapped in Dunlop SP8000's. Viper car alarm. Clear corners.
    All A/C equipment is gone. Just the heater remains
    I have the title and it's clear. Bill had a CarFax done on it a long time ago and there was nothing bad on it. ALOT of documentation you'll get, along with some other stuff, like the first issue of Car Magazine that compares the MR2 with the Ferrari 308, a BGB (big green book) for the '86 AND the '88 (since it has a supercharged engine in it), along with a Haynes manual.
    big box of hardware (has tons of big metric bolts, like the ones that go through the motor mounts, etc. These come in handy if you need to put the engine on an engine stand. I put some other stuff in just now, like a bunch of light bulbs, a can and bottle of touch-up paint, supercharger oil, etc. There will be a lot of spare hardware
    Only small issue I get some brake shake in the steering wheel when I brake hard at around 45 mph. Not really a problem it does not hinder the braking ability.
    I am in Knoxville,TN
    Thanks for looking
    -Adam
    Please pm with further questions
    Vin number will be given in pm if asked
    Pictures to follow
    Knoxville, Tn
    Comes with alot of spare parts That have been sorted and listed to which box they are in.
    list of spare parts:
    Actuator Assy., Power Mirror, LH
    Actuator, Cruise Control
    Ashtray, 85-86
    Battery Tray, Plastic
    Bezel, Dash, Eyeball Vent, RH
    Bezel, Handle, Door, Inside
    Bolt, Pulley, SC Tensioner
    Boot, Rubber, Throwout Fork
    Boot, Shifter, 1 VG cond.
    Bottle, Windshield Washer
    Bracket, Engine Bay Temp. Sensor
    Bracket, Spare Tire Holder
    Brake Master Cylinder & Booster
    Brake, Emergency, Cable Assy.
    Bushing, Shift, Square
    Cable Assy., Accelerator
    Cable Assy., Engine Hood Release
    Cable Assy., Frunk
    Cable Assy., Fuel Door
    Cable Assy., Speedometer
    Cable Assy., Trunk, Rear
    Cable, Shift, Front/Rear
    Cable, Shift, Left/Right
    Caliper, Front, LH
    Caliper, Front, RH
    Caliper, Rear, LH
    Caliper, Rear, RH
    Canister, Charcoal
    Cap, Fuel
    Cap, Oil Filling
    Cap, Oil Filling
    CD Changer Mounting Hardware
    Clip, Sunroof retaining
    Clock
    Cluster, Gauge
    Coil Assy., Ignition
    Cover, Front Strut Top
    Cover, Fuse Block, Engine Bay
    Cover, Fuse, Driver's Kick Panel
    Cover, Ignition Coil
    Cover, Positive Battery Cable
    Cover, Rear Strut Top
    Cover, Spare Tire
    Cover, Timing Belt, Lower
    Cover, Timing Belt, Middle
    Cover, Timing Belt, Top
    Cushion, Hood Bumper
    Deflector, Wind, Sunroof
    Door, Console Box
    ECU, Supercharged
    Emblem, Hood
    Faceplate, Radio Surround
    Fan, Engine Bay
    Fan, Radiator
    Fasteners, Mk1 Front Spoiler
    Felt, Steering Column
    Filler Assy, Water
    Fork, Throwout Bearing
    Front Hub Assy., Complete, LH
    Front Hub Assy., Complete, RH
    Fuel Door, White
    Garnish, Front Door, Pass. Side
    Gasket, Center Engine Cover
    Gasket, Cold Start Injector
    Gasket, Idle Speed Control
    Gasket, O-Ring, Water Bypass Pipe
    Gasket, Plug Valley
    Gasket, Timing Belt Cover, Top
    Gasket, Valve Cover
    Gaskets, Kbox C-Pillar Kit
    Gaskets, Kbox Distributor Kit
    Gauge, Boost, VDO
    Grate, Cigarrette
    Grille, Lower Radiator
    Grille, Speaker, Front Left
    Grille, Speaker, Front Right
    Grommet, Rod, Prop, Engine Hood
    Guide, Timing Belt
    Handle, Door, Outside, Drivers Side
    Handle, Door, Outside, Pass. Side
    Handle, Oh ____
    Hangar, Exhaust Tail Pipe
    Hangar, Exhaust, Rear Engine Bay
    Headlights
    Horn, High Tone
    Horn, Low Tone
    Hose, Radiator Flush/Fill
    Hoses, SC
    Ignition Switch Assy.
    Injectors, Fuel, GZE
    Insert, Tail Mod, Plastic
    Knob, Light Control
    Knob, Seat, Lower Side Bolsters
    Knob, Seat, Side Support Adjust
    Knob, Shift, Momo, Chrome
    Knob, Wiper Control
    Label, Shift Pattern, Console
    Lamp Assy, Marker, Front, LH
    Lamp Assy, Marker, Front, RH
    Lamp Assy, Marker, Rear, LH
    Lamp Assy, Marker, Rear, RH
    Lamp Assy, Turn Signal, Front, LH
    Lamp Assy, Turn Signal, Front, RH
    Latch Assy., Engine Hood
    Latch Assy., Frunk
    Latch Assy., Trunk, Rear (Luggage)
    Latch, Sunroof Holding
    Latch, Trunk, Rear
    Lever, Luggage & Fuel Door
    Lever, Release, Frunk
    Light, Dome, w/Lens
    Linkage Rod, Throttle
    Lock, Trunk, Rear (Luggage)
    Louver, C-Pillar, Plastic, LH
    Louver, C-Pillar, Plastic, RH
    Master Cylinder, Clutch
    Mirror, Rear View, Inner
    Module, 40A, Green
    Module, 50A, Red
    Module, 60A, Yellow
    Module, Buzzer
    Module, Circuit Open
    Module, Cooling Fan
    Module, Cruise Control
    Module, Door Control
    Module, Flasher
    Module, Flasher
    Module, Headlamp Control Relay
    Module, Headlamp Retainer
    Module, Headlight Retractor Control
    Module, Power Window
    Module, Speed Control
    Motor, Cooling Fan (Radiator) #1
    Motor, Headlight, LH
    Motor, Headlight, RH
    Motor, Heater Blower
    Motor, Power Window, LH
    Moulding, Windshield Side, LH
    Moulding, Windshield Side, RH
    Moulding, Windshields Side, Int., LH
    Mount, Engine, Front
    Mount, Engine, LH (Tranny Side)
    Mount, Engine, Rear
    Mount, Engine, RH (Pass. Side)
    Mounting Sleeve Bolt, Oil Filter
    Nozzle, Washer
    Pad, Felt, Top of Dash
    Pads, Brake, Front, Mk1
    Panel Assy., Sail, LH
    Panel Assy., Sail, RH
    Panel, Driver's Kick, Plastic
    Panel, Housing, Steering Column
    Panel, Over Gauges, Plastic
    Panel, Rear 1/4 Window (2 Pc.)
    Panel, Seat, Driver's, Bottom Left
    Panel, Under Dash, Plastic
    Panel, Under Glovebox, Plastic
    Panel, Wall Behind Door, Driver's
    Panel, Wall Behind Door, Passenger
    Pipe, Water Bypass, No. 1
    Plate, Door Sill, RH or LH
    Plate, Shift Pattern, Console
    Power Door Lock Module
    Power Window Motor, RH
    Power Window Regulator, LH
    Power Window Regulator, RH
    Protector, Hood-Headlight, Plastic, LH
    Protector, Hood-Headlight, Plastic, RH
    Protector, Wiring, Frunk, LH
    Protector, Wiring, Frunk, RH
    Pulley, Water Pump
    Pump Assy, Cruise Control
    Pump Assy., Windshield Washer
    Radio Faceplate Box
    Relay
    Relay, B4
    Relay, M3
    Relay, M4
    Relay, Starter
    Resistor, Fuel Injector
    Rod, Prop, Frunk
    Screen, Debris, Cowl, Long
    Screen, Debris, Cowl, Short
    Seal, Hood to Radiator
    Seal, Oil, Camshaft
    Seal, Transaxle Oil (spare)
    Seat Belts
    Sender, Fuel Level
    Sensor, Engine Bay Temp w/Bracket
    Sensor, Water Temp (For EFI-Green-In Head)
    Sensor, Water Temp, Radiator
    Shaft, Pulley, SC Tensioner
    Shifter Cable Lever, Metal, Tranny
    Slave Cylinder, Clutch, w/plate
    Spring, Timing Tensioner Pulley
    Stalk, Cruise Control
    Strainer, Oil
    Strut Rod Assy., Rear
    Sunroof Parts, Misc
    Support, Sunroof Mounting, LH
    Surround, Headlight, Plastic, Pass.
    Switch Assy., Rear Window Defog
    Switch, Brake (No Cruise)
    Switch, Clutch
    Switch, Defroster
    Switch, Door, w/ Rubber Boot
    Switch, Headlight
    Switch, Power Mirror
    Switch, Start Inj. Time (Coolant Temp)
    Switch, Window, Drivers Side
    Switch, Window, Passenger Side
    Switch, Wiper
    Thermostat Housing w/Temp Switch
    Timing Pointer
    Trim - Frunk, Plastic
    Trim, C-Pillar, Center
    Trim, C-Pillar, LH
    Trim, C-Pillar, LH
    Trim, C-Pillar, LH, White
    Trim, C-Pillar, Middle, White
    Trim, C-Pillar, RH
    Trim, C-Pillar, RH
    Trim, C-Pillar, RH, White
    Trim, Door, Upper, Outer, LH
    Trim, Door, Upper, Outer, RH
    Trim, Eyebrow, LH
    Trim, Eyebrow, RH
    Trim, Headlight Retaining
    Trim, Water Overflow Bottle
    Trim, Windshield, Upper
    Tube, Tie Rod Adjusting
    Valve, A/C Idle Up
    Valve, Orange/Black
    Vent, Eyeball, Driver's
    Vent, Side, C-Pillar, LH, White
    Vent, Side, C-Pillar, RH, White
    Vents, Side, Rear Window
    Water Outlet Housing, Head
    Wiper Motor
    Wiper, Windshield, LH
    Wiper, Windshield, Refill
    Wiper, Windshield, RH
    Yoke (U-joint), Steering Column
    There are other parts not on the above list, like side and rear glass and a spare left front fender, for example...
    I have a few brand new parts that I've recently purchased that I haven't installed, yet, like 4 iridium plugs, and a new O2 sensor so I could start fresh when I tuned her.
    Knoxville, Tn
    Damn, that is one long ass list and a nice ass car.
    Knoxville, Tn
    Thank you very much
    Your House.
    nice duece...i'm thinking about picking one up in the next month
    Knoxville, Tn
    Thanks
    They are fun cars.
    SoooperDooooperLS
    nice car, gl on the sale
    Cruzan Boy Siverprobegt's Avatar
    ga/VI BREED
    Cleanest mr2 ive seen in a while,g/L
    92 mx3
    OMG IS THAT Mr.Wong? justwongit's Avatar
    yeah that is one clean ass mki i love that model. good luck with your sale.
    Knoxville, Tn
    Thank you all
    Banned savanna13's Avatar
    Badass.
    I remember seeing your cars in a MR2 Showcase on MR2board.com, i remember the racing stripping paintjob. you said the PO had the name Bill and you have an immaculate mr2... was the PO BillWot, BillStrong....?
    Knoxville, Tn
    Thanks
    It was Bill Mertons car. bmerton on MR2OC.COM Great guy thats had tons of MR2s lol.
    Drives a Honda Jin's Avatar
    Carrollton
    Wow the list of parts is probably enough to build another mr2.
    2004 G35 Coupe (Sold)
    1998 BMW M3 (Sold)
    =P DDam's Avatar
    Lawrenceville/Atlanta
    Very clean looking car. Seems like original supercharged mr2's are pretty hard to come by these days.
    :english:
    Senior Member SE-Rious©'s Avatar
    good luck on sale.nice car.
    Knoxville, Tn
    Thank you
    VDUB BiH1320's Avatar
    dammn its clean as hell. goodluck on selling it.
    Knoxville, Tn
    thank ya
    hattiesburg MS
    bump for a clean MK1
    Knoxville, Tn
    Thank you
    Love that 2.5RS of yours.
    Knoxville, Tn
    Please let me know by way of pm if anyone is interested. Or just post in this thread.
    Thanks
    -Adam
    free bump.... cause MR2s are awsome...
    Canton, GA
    man i wish you would keep this...ive seen it before at aw11 meets in SC, and that thing is MINT! makes mine look like a beater....if i had 5k i would take this off your hands in a heart beat!!!.....or if you wanna trade for a 89 MKI Silvertop 20v ill do that as well lol...
    not fair...
    u should have said u'd take a trade for a 93 eg that may burn a lil oil like killers....
    then u'd be in business.. lol..
    good luck love the car. wish i had some boot.. or could sell this thing.
    Knoxville, Tn
    Quote Originally Posted by Sport20
    Thank you
    If I can not find a good trade or some extra cash then I will very happily keep it.
    Knoxville, Tn
    not fair...
    Thanks man
    Sell that car lol.
    Also interested in a SR20DET powered 240 with upgrades.
    Knoxville, Tn
    May consider a nicely built fwd car.
    Canton, GA
    define nicely built, and too what price range? ive got a friend with a 2003 Mazdaspeed Protege he is thinking of selling. its a Turbocharged 2.0, LSD FWD, Tein Coilovers all around, Racing Beat: (front and rear sway bars, strut bar) AWR (motor mounts, short shifter), Injen intake, Turbohoses upgraded sidemount IC, 626 intake manifold, Rota Slipstreams on Yoko ES100's, and a bunch of interior work. the car is fast in a straight line (mid to low 200whp range in a light chassis), but handles like no other car on the road.
    Knoxville, Tn
    I am just looking for a straight up trade. I have no money to offer. Car needs to be around the $6,000 mark. Because I could sell this car for that.
    But to tell the truth I would rather the fwd car be built for n/a power and torque.
    Knoxville, Tn
    Would love to find a modified MK3 Supra or RB20DET, RB25DET 240SX.
    Certified Gearhead Mk3Jesse's Avatar
    dang that mr2 is so sick!! to bad my mk3 isnt modified lol.
    Knoxville, Tn
    Quote Originally Posted by Mk3Jesse
    Thanks
    I like that MK3 of yours. It would just take a bit of cash plus the car for me to trade
    Just so I could do some power modifications
    Quote Originally Posted by LongShot
    Thanks
    lol, im on the same boat as you as far as the cash goes. i dont have much to throw around. And besides the supra is not even running yet the new engine is not actually in it yet, i never really have time to work on it
    Knoxville, Tn
    Oh well lol
    Good luck with the engine install.
    ttt
    Knoxville, Tn
    Thanks
    Thinking of trading for my friends 3000GT VR4. Hmmm I would most likely trade it after I got it lol.
    Canton, GA
    Thanks
    wow have fun workin on that Marvel of Engineering lol
    Thanks
    u should just keep ur mr2 until it decreases in value.. and then i can buy it.. one day.. lol..
