Thread: FLAT PANEL FOR SALE...CHECK IT OUT!!!!
    OL SKOOL 6IMAFREAK9's Avatar
    Default FLAT PANEL FOR SALE...CHECK IT OUT!!!!
    NEW IN THE BOX!!!
    LCD Panel
    19" SXGA TFT LCD
    2 Dual CCFTS
    376.32 mm x 301.056 mm Display Area
    Display 16.7M colors
    Ultra Crystal Clear Bright Display
    Resolutions
    1,280 x 1,024 / 75Hz
    Brightness & Contrast Ratio
    Brightness: 400 nit (cd/m²)
    Contrast Ratio: 500:1
    Response Time
    12 ms
    Viewing Angle
    140º (horizontal)
    140º (vertical)
    Input Signal and Connector
    Composite video with RCA jackS-Video
    1.5 M detachable cable 15-pin mini D-Sub VGA Connector
    TMDS DVI (Digital Visual Interface)
    24-pin DVI Connector (DVI Cable optional)
    Audio with 3.5mm mini jack
    User controls
    Power on/off, OSD (On Screen Display), Contrast, Brightness, Clock, phase, H-Position, V-Position, H-Size, V-Size, Graph/Text Mode Selection, Auto-adjust, Color Temperature, Audio Volume, OSD H-Position, OSD V-Position, Display Mode Detection, Show Firmware Version, and Reset: Basic Setting, Position, Miscellaneous, & All Functions Features
    Flicker and Static Free
    PNP: DDC1/2B (Analog), DDC2B (Digital)
    Less Than VLMF Radiation Standard
    Panel & stand
    Factory presetting mode: 41
    Ergotron Arm Compatible (VESA 100mm)
    Audio
    Stereo speakers with amplifier (2 Watt /channel)
    Power Source
    100-240 VAC
    50W Max
    Certifications
    UL, C-UL, TUV/GS, CE Mark, FCC-B, VCCI, TUV-Ergo, TCO 1999, EPA
    Scanning Frequency
    Analog: 24-80 kHz (H), 50-75 Hz (V)
    Digital: 30-80 kHz (H), 50-75 Hz (V)
    Size and weight
    Gross: 20 lbs Net: 16.4 lbs
    Package: 23.5" (W) x 20" (H) x 6" (D)
    w/Base : 16.5"(W) x 16.25"(H) x 8.5"(D)
    w/o Base : 16.5"(W) x 15"(H) x 2.5"(D)
    Attached Thumbnails Attached Thumbnails -19in-monitor-jpg
    Apr 2003
    price?
    Everyday im HUSTLIN'
    atlanta,ga
    says $350 at the bottom of the post.
    Apr 2003
    Quote Originally Posted by AtifSajid
    I thought 350 is the price shown on the webpage that he printscreened from. IMO, 350 is a bit high considering I bought a 19" dell for $220 shipped (it's one of them special deal they had).
    I'm half-interested since I want to replace my IBM 17" LCD with another 19" for dual monitor because it's kinda awkward having a 17" and 19" setup together.
    Exclamation TALK TO ME
    I PMED YOU. LETS MAKE A DEAL!!!
    bang Danny's Avatar
    Sep 2003
    Smyrna
    pm me. i wana deal it up!!!
    Exclamation A MAN
    AFTER MY OWN HEART!!!!
    IM PMING YOU RIGHT AFTER THIS!!!!
