Thread: ef turns over no start
    Angry ef turns over no start
    i have an 90 ef swapping 90 ls b18 the car turns over but doesnt start checked spark has spark compression is fine changed ecus and same problem its throwing cel #8 it calls for tdc sensor checked wires and they are fine so replaced dizzys and still same problem and the injectors are not opening and replaced those same problem i need all the help i can get please
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    did you put the plugs (on the harness) in the correct location?
    {side note -- http://www.importatlanta.com/forums/showthread.php?p=35366542#post35366542}
    which lugs on what?
    ECEFC.com
    did you go from dpfi to mpfi?
    yes i did
    ECEFC.com
    It might have something to do with the wiring of the dizzy, so back track your wiring there. I dont remember what need to be switch but here
    http://crf50.no-ip.com/fourthgenhatch/mpfi.html
    this might help
    known as Charles
    Did you use your original dpfi engine harness or did you use a mpfi harness? Also, you have to add two wires from the dizzy to the ecu if you used the dpfi. Here are couple of links that may help. Finally you cannot use a mpfi harness in a dpfi car unless you change the harness that goes from the shock tower to the ecu.
    http://tech.hybridgarage.com/tech/4g...-zc-wiring.htm
    http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    thanks charles for the info ill try it out retrace my steps and see what i did wrong
    thanks to all i finally cranked and runs great what turns out is that the car had an Hasport harness and all the dist. wires are all ready runed no need for that so that was the problem but thanks a million
