Results 1 to 13 of 13
Thread: Blown head gasket?
    Default Blown head gasket?
    I just got one problem fix on my car but now it seems like theres another one..."00 civic si" when i turnt on the car today it seems like there was a little bit of white smoke coming out from my tailpipe but tats only after i let go of the acceleration... i also notice that either steam/smoke was also coming from the radiator could it be a leak? man tats wat im hoping cuz replacing a head gasket will be...yeh lol..if any1 can help me or know who/where i can check my compression it would really be appreciated. thanks
    AKA Stock_dc2 torqlswonder's Avatar
    you can do a compression test on your own its not that hard you can do it in 25 mins tops but i doubt that would be your head gasket becuase you would no if it was your head gasket you would b smoking a whole lot more trust me you would know.
    lol if tats the case then man i feel alot better...but still just to be on the safe side, how can i do the test by myself and what would i need...
    ill tell you what where you located at?
    Memphis, TN
    go to autozone, get a compression kit. hoses and gauge, and fitting for your spark plug hole. cost like 50 bucks.
    Blah Blah Blah!
    Appreciate it latoilette...
    "slower_than_you" lol no offense man but if i tell u where im located then my civic will just end up like ur teglol jk
    i was just wondering because i was going to see if you wanted me too do it or show you how i have the tools no need to go buy them. but take it how you wanted lmk if you still need my help.
    your moms house
    i dont know about the smoke thing but you may have a cracked resevoir or bad radiator cap...try the obvious things first
    FUCK B&D COMMUNICATIONS!
    smyrna
    does it overheat sometimes?
    The Don TheGodfather's Avatar
    Check coolant levels. If there is no overheating, that is a good thing. The biggest warning sign is overheating. And what others said, do a compression test. That will help. Def. keep an eye on the temperature gauge.
    WEST_SIDE
    Quote Originally Posted by bboystyles
    what other problem did you have that you fixed? does it over heat/ run hot ?. does it always smoke at idle when hot and cold?
    +1 for all the advice...I checked and there wasn't any leak in the radiator or reservoir but it could be a faulty radiator cap but as for the white smoke from the exhaust i still cant find the prob...its constant but not tat noticeable. temp is fine it doesn't overheat. lol and "Slower_than_you" i was just kidding with you man, no hate.. if you're able to give me a hand just hit me up man.. thanks everyone
    No overheating is a very good sign. The light white smoke could even be some carbon build up in the muffler. When I first got mine I had some white smoke, not too noticeable, then it went away. I would also reccomend changing the oil and spark plugs if you haven't in a while, just to elimnate any possible issues.
