Results 1 to 10 of 10
Thread: Question about rear rotors
    :noitacoL
    Default Question about rear rotors
    Just a quick question, just wondering if what i have heard is correct.. if rotors on integras, civics, and del sols are all the same? (9.5") And the Same with pads are they all the same?
    Also, how difficult is it to change the rear rotors?
    Mine crapped out on me tonight on the way home...
    Hampton, Ga
    you have drums or discs
    Acworth
    true as long as its not a type r. and it is very easy to change. you may need an impact driver to get the screws out if they have not been replaced.
    Acworth
    ps- how do you know that "crapped" out on you? usually it takes a while for them to start "crapping"
    4G15 powered
    Covington
    What kind of car because not all of them are the same.They are very similar in appearance but as for performance and bolting on they are not all the same
    :noitacoL
    They are disc.
    Quote Originally Posted by jdmjames
    Well when i would go into reverse my brakes would make a sound which i assumed was the brakes. The other day I got some work done at mahdavi and they mentioned that i needed new pads, and that i may need new rotors if there's vibration upon braking (which there was). And now when i brake, and come to a stop, there's a terrible scraping noise, and my rotors look worn and rashed on the edges.
    :noitacoL
    All this is on the rear rotors. I am replacing all pads tomorrow, and was just wondering how difficult and time consuming it is to change the rear rotors, and which ones to get.
    Acworth
    ^ yeah sounds like pads and rotors. easy fix.
    Hampton, Ga
    the scraping noise is because u need to pads but i would change the rotors too. you need a impact drive for those stubbord screws.
    once you pull the brake caliper off you can remove the rotor
    :noitacoL
    awesome, well thanks for the help everybody
