Thread: Clutch slipping maybe?
    ..and your point?? Whitebandit's Avatar
    Albany/road less traveled.
    Default Clutch slipping maybe?
    When I shift into second gear and really get on it the motor revs way up like its not in gear or the clutch is slipping or its just spinning the tires. Ive not really seen black marks and I know its in gear so that leaves me on the clutch. Its a brand new 6 puck clutch I installed myself. Any input would be great. Its a cable converted to a hydro trans.Its a turbo b18a1 that goes into boost about 2200 rpm.
    in a paint booth
    yea it is probably just spinning
    Ridin' in tha chevy Sack Attack's Avatar
    Covington
    easy way to really tell is pull your e brake while going slow in first, pull the brake and nail the gas....u will tell then for sure
    You REARRY liek me! scabtastic's Avatar
    powder springs
    i dunno...when i get on the motor in first and slam second my car sits at 5k for a little while and then goes...but i have a stock clutch thats got about 108k on it.
    Epic Foxbody Thread Crew Member #07
    Fuck Bitches, Kill tyrannosauruses
    Where Am I
    Quote Originally Posted by scabtastic
    yea that sounds like clutch to me....
    powder springs
    Quote Originally Posted by 97GSRb18
    im savin up for one...i think the flywheel needs to be replaced too...or atleast resurfaced...sometimes i leave 1st i get a squeeling noise...
    sorry to thread jack
    Go out and put the car in 4th, get the rpms up to 2300-3300(depends on car) and floor it. If the rpms rise as you are hitting peak torque but your speedo is not increasing, then you need to look for a new clutch
    Thanks for the info.
