Thread: tranny ?
    Your mom's bed
    Default tranny ?
    The other day on my way back from skool i was stuck in traffic and felt a knock in my pedals shifting form 1st to 2nd. I turned down my music and began to listen didn't hear it angain until like 20min. later. I was once again shifting from 1st to 2nd and hear the knock and also felt it in the pedals. Is my transmission slipping or is it something else ? I really need to know What this might be, cuz i travel everyday to Gwinnett Tech from Henry county for skool.
    Gainesville
    need more info.. but is is posible your tranny is slipping
    Your mom's bed
    Everytime i change from 1st to 2nd i hear like a clunking noise, i can also feel the clunking in the pedals. But only when shifting from 1st to 2nd, and it's happen 5 or 6 times in the past 3 days.
    LAWRENCEVILLE
    check for broken motor mounts.
    Hella stock member!
    Super Dave Z U L8R's Avatar
    Roswell
    ^^ most likely a motor or tranny mount, put up the e-brake and get a friend to let the car in gear slowly and give it a little gas (it's called brake-torquing) try it in 1st and then in reverse, what you're looking for is excessive movement of the engine, that'll let you know if there's a mount bad, while they're brake torquing the motor you'll be looking at the mounts to see if any are broken, gl
    Your mom's bed
    Quote Originally Posted by Z U L8R
    Well the clunking did happen at all today. I drove to skool and work never heard or felt a thing.I tryed moving of at different speeds and engine Temps to see if it was the tranny. 1st i moved off real slow NOTHING . 2nd moved off like i normally do NOTHING . Last one i reved up to 4G's and poped the clutch and Nothing. So im going to keep listening and it it picks back up ill probably take it to Amco transmissions by my house.
    Thanx ill try it tomarrow
    Also would i have to remove the spray guards to see if it is the tranny mounts?
