Thread: d16 greddy kit on a b16 or b18
    Senior Member 00CIVICSI's Avatar
    Augusta,ga
    Default d16 greddy kit on a b16 or b18
    Im looking at a civic with a d16 greddy kit ( full kit with E-manage and all) i was wondering if i swap in a b16 or b18 what will i need to make the kit work on the b-sersis motor. beside the manifold and downpipe? thanx ( not a turbo nerd dont know much)
    Slow... mp5o's Avatar
    Its not p-manage.... Its E-manage......
    Augusta,ga
    maybad bad, are 94-96 teg ls motors obd1?
    A.K.A Felipe Gomez Negrodamus's Avatar
    Daaaaaaknessss
    i own the greddy kit for the SI. and honestly "I THINK" the only thing u'll be using from the D kit is maybe oil lines and the Td04-15g which is prolly too small and will spool too fast. Also you'll prolly wanna upgrade the injectors. You will not be able to use the blue Box because that is because its specific to the sohc ecu, you'll prolly be better off removing the kit and selling it and use the money for a better kit...my .02
    Augusta,ga
    thanxs
    Certified Gearhead bluuuurr's Avatar
    Oct 2003
    Monterey, CA
    you can use everything except the turbo manifold... the blue box will work on your DOHC motor as long as you keep the 310 injectors
