This is my first time attempting to get the timing right. I just put a new distributor and its off timing cause the car tries to start but it kinda of coughs when trys. please any help info will be appreciated.
put it in the middle. The car should start easily though. Check you firing order
You can install the Dizzy 1 way an it can move 1/4 turn both ways an will start in any of those ways...you got the ignition firing order off....Its 1-3-4-2Originally Posted by swolejamaica
Could it be 180 off?
Back to being stock and slow
NO because the Dizzy will only go in one way SO No...Firing order is OFFOriginally Posted by Motivation
believe or not it will go in the wrong way. on problems is the second u spin the motor over its going to break the dizzy. now dont get me wrong its not easy to get it the wrong way but ive seen it done.Originally Posted by JoshuaASE
you know ive heard people say it goes in "wrong" but ive never been able to do it.
It either slides in or it doesnt. I mean i supposed if you FORCED it in and ran the bolts down, but ive never gotten it to slide in wrong.
Usually it bottoms out an wont slide onto the cam.
Correct...if someone forces it an bolt it down they have to be a complete TARD to do that!Originally Posted by Mr. KiDD
i would not put it past some people. lolOriginally Posted by JoshuaASE
Hella stock member!
lololol..True
yea just got home and im going to give that a try!! update soon
welll
GOT IT!!!!
If you don't give me heaven, I'll raise hell!!!![SIGPIC]
