So Mom took my new car this morning to get the emissions on it.. fucking thing failed.. bad.. so what do I do now? I has a repair form which I have to get filled out..
Val For President
R.I.P. Our Dear Leisa..
ASAP N.E. Chapter VP
No more supra
NIKON Squad member| NikonD40
well.....how bad failed..what year is it?
what failed? sometimes a cat replacement does the job perfect. othertimes...its alot worse than that.
its a 1994
the hp was alittle over.. the co was a bit over.. the cat part was 3 times over..
Val For President
No more supra
I know people have "hook ups" on emissions.. my question is.. Since I have failed once.. and it gets redone.. would it work?
Val For President
No more supra
sounds like what happened when i got mine dont and failed...
i just replaced the cat and it did just fine.
gas cap didnt work either..
Val For President
No more supra
Originally Posted by Mycivicjust8u
well if i were you id replace the cat and cap
Well I've got 30 days to fix it.. I guess Ill be going to Nopi with it and then taking it to batlground next week..
Val For President
No more supra
what kind did you you buy?
maybe 2 or 3 min.. I drove from the bank straight over to emissions..Originally Posted by uproot
Val For President
No more supra
LOOK AT MY SIGNATURE... HELLO a Supra..Originally Posted by rickgiblin
Val For President
No more supra
both... they did the dyno and put a thing in the exhaust pipe...
Val For President
No more supra
i think like...98 up is just pluggin inOriginally Posted by uproot
everything else is on a dyno.... but i could be wrong.
She bought it in Tenn... they do not require emmissions there... I didn't even think about that when you said you were going to Tenn to look at a car...
~In life it's most important to find a world that belongs to us. Life is meaningful only when we can find this world.~
wow, sorry. there goes my head for the dayOriginally Posted by Mycivicjust8u
i think so..Originally Posted by uproot
Val For President
No more supra
yea ive heard to make sure that its warmed up all the wayOriginally Posted by Mycivicjust8u
Val for President
Yea the car needs to be driven for a good 30 mins.The cat needs to be smokin hot!! Id say drive it on the hwy for a good 30 45 mins and go get a practice test run and see what it does.Im a toyo lexus tech thats all i work on all day. Def need 96 and older car to be driven for a good while or else you will fail.
YEA...IM AN ASSHOLE
i think that your 100% correct, but i may be wrong. well good luck with getting your car passed. hope it all works outOriginally Posted by 5thgcelica
soooo what'd id do. again..gas cap, cat, and run some higher octane fuel through it.. sometimes it'll give you just enough edge to pass it.
96 and up is OBD test where they just plug inOriginally Posted by 5thgcelica
YEA...IM AN ASSHOLE
Thanks... that may be what the problem was... also i have something of yours you might want before nopi..Originally Posted by dereksi
Val For President
No more supra
gotcha.... thanks for clearin that up.Originally Posted by dereksi
Thanks guys.. I am running on premium now.. but the car was still cold so...
Val For President
No more supra
Go drive it for awhile and get it real hot and see if they will run a practice test for you
YEA...IM AN ASSHOLE
no smoke at all...
Val For President
No more supra
hey, how did you find your supra? did you use trader or something? just currious, im looking for a new car
Supra Forums... the best place...
Val For President
No more supra
DEREK WHEN DO YOU WANT YOUR DANG MASK.. ITS SITTING IN MY CAR
Val For President
No more supra
from what I have heard turbo cars will fail emissions like every one said unless it is warmed up. I know Japan went to cold emissions and it hurt a lot of the turbo cars over there because they were all failing. Congrats on the car tho
Thanks.. and i think i got it taken care of.. THANKS ALOT EVERYONE
Val For President
No more supra
