A dsp amp that came off my 95 740i, and the 6cd changer(with bracket) I have got aftermarket amps and speakers in my car so I don't need this anymore.
It works perfect and sounds amazing, There are no issues whatsoever. I also have the bracket, the connector pins and another wire which I can also send at no extra cost.
I am not exactly sure but I have heard that it will fit 96 to 2000 cars with dsp system. Most likely the amp will work without programming, but some of the car-specific features may not integrate until programmed. Again, this is true no matter which DSP amp you buy.
Part # 65. 12-8 352 296
Phillips 22 DP 603 (9022 236 03239) PHILLIPS MADE IN GERMANY
Original Equipment DSP Amplifier, 1996 Phillips version.
Not sure which amp you need? Read below for some information.
part# 65 12 8 352 296, crosses to these numbers: xref# 65 12 8 362 175 xref# 65 12 8 372 197 xref# 65 12 8 375 788 xref# 65 12 8 376 053 xref# 65 12 8 376 262 xref# 65 12 8 377 936 xref# 65 12 8 386 281
BMW went through a lot of part numbers and several makes, so it may be difficult for you to assess compatibility with your car. Above are the various part numbers that can replace each other, according to BMW parts catalogs
Asking $200
E39 E38 E53 BMW High Instrument CLUSTER w/ 46K Miles. It has three plugs on the back, 1 blue, 1 black and 1 white. With the on-board computer option. An easy way to spot the on-board option is the wide information display, along with two instead of just one black reset buttons that go through the clear front bezel. What you see in pictures is what you get, I connected It... does work and all the fuctions work.
WITH CROME RINGS AND CARBON LOOK.
asking $200
