will i get any kind of increase out of this ?
dnwp
isn't a6 head dual point and not multi point?
its mpfi
dnwp
anyone?????
dnwp
just use the camshaft. its more aggressive!
+1 i have a b7 cam in a d15b1, the 70 hp model. i had to switch the throttle body, but the a6 im should be better than my hacked up hatch in my sig.Originally Posted by bigdare23
save up for something more than 100hp come on now
not worth it dude buy a Z6 head and call it a day . !!!!!!and push around 130 ish Hp .a6 head flows better than a b7 ... but a z6 beats all of them .so jus spend 100 on the head and do a minime swap ..
93 sol Si
95 sol S
95 sol Si
Originally Posted by minniemeSol
the b7 cam was free!!! that and i have a complete z6 swap for it that i am rebuilding!!! i would go vtak over non. but if you have a cheap ass 70hp like mine, the cam swap works wonders. with a car this light, the z6 would be good, or even a y8
well let's takes this question in several steps. first off, let's take the dual point and not multi point answer.
dual point - 2 injectors (d15b2)
multi point - more that 2 injectors(d1616)
now that we got that out of the way lets take the next part.
head - the d15b2, d16a6 and the d15b7 all are made from the same head casting. the difference is the cams and springs(well get back to this).
sohc cams - the d16a6 is the better cam but you can put this cam in to the d15b7 head w/a d16y7 or d16y8 cam gear(they're the same cam gear) to make it work. the y7/8 cam gear would make TDC w/o any headache, just put it tdc and go. now i want to make a extra footnote about the ZC non vtec cam. a d16a6 cam and a zc cam are the same cams the only differece is that a zc can is retard 5*(4.75* to be exact) so it gives an aggressive profile. you can have the same aggressive profile w/an adjustable cam gear to the d16a6. and w/a y7/8 cam gear on a zc cam it will be tdc too in a d15b7.
springs - the first question should be what year is you d15b7 head? why? well in the later 94 honda ran out of d15b7 head spring so the went on and used d16a6 springs. hence the d16a6 spring are a bit stronger than the d15b7. and they are good up to 8k reving for the ricer.
so in final why slap on a d16a6 head when all you have to do, is just slap in the a6 cam w/a y7/8 cam gear to have the same head?
and finally the magic question if the d15b2, d16a6 and the d15b7 are the same head why do they have different hp. simple the ecu tuning w/cam profile, and several other things. but in a N/A engine alot of the hp is made from the head and tuning.
Speak English Or Die!
1 monkey power = 0.332 hp.
Originally Posted by remoer
the cam i used was from a 95. i checked the oem part #'s for every valve component and they were the same. so a lot is interchangabel. depends on what the long run goal is. im a cheap ass on my hatch, for now!!!
let me add cause i've notice there's been so talk of the mini swap and z6 head. just for the record you can't swap a vtec cam and a non-vtec cam. in other words you can't put a a vtec cam in a non-vtec head and vice a versa. i'm only saying it before some idiot ask: "can i out a z6 cam in my a6 head?" un no!
thanx for the write up! you have been repped!
dnwp
i hope nobody askes that question. the rocker assembly is way different, valves, etc. no vtec solnoid. vtec=vtec, non vtec=non vtec thanks for clearing that up, could have gotten ugly for some poor kid.Originally Posted by remoer
you would not believe the question i've heard ask over the years on the internet so nothing suprises me. lol.Originally Posted by preferredduck
