So, I need someone close that can pull a broken bolt out of an aluminum head.
The bolt is broken off in the head, meaning there is none sticking out and its not flush. This will have to be drilled and pulled out, or drill it a size bigger and tap new threads. Sounds easy, well here is the hard part... I need the head to stay on the motor, its tight and not much room and to make it worse its one in the back. Goza said $30 to fix if I remove the head (thats alot of work in this tight area) not to mention gaskets and little stuff.
The car is a '95 Camaro Z28 LT1. Its the driver side head (easier of the 2), I have the manifold off, will need the brake booster removed and the steering shaft unhooked I'd imagine.
Anyone thinks they can do it or have more questions PM me.
PS: Dont solicit any busniess, just PM me
