Results 1 to 40 of 45
Thread: nvmysrt: Questionable Seller
    Teh rock smoker R3RUN's Avatar
    Atlanta,GA/Tampa,FL
    Default nvmysrt: Questionable Seller
    *******UPDATE********
    nvmysrt and myself have resolved our issue. I would like to say that we were able to work something out that I believe is fair and square. This being said I want to leave a couple of reminders for anyone that may be buying anything any time soon.
    1) Make sure to be very thorough with your inspection of something before buying.
    2) Keep a cool head.
    3) Ask lots of questions before buying.
    4) Try to arrange some sort of agreement on any possible refunds if you have any reason to think it may be necessary.
    Not all situations will turn out the way this did. Though it was a hassle for both parties involved, a larger hassle was avoided because those involved handled the process in a semi-professional manner.
    In closing I would now consider nvmysrt a decent seller. I may not ever do buisness with him again but I don't think he is out to screw you.
    Blacc Panther member
    look to ya left
    damn man... sorry to hear that....
    Atlanta,GA/Tampa,FL
    I have continued to try and contact him today with no luck. Check out this thread to see what I am talking about, specifically starting at post #17:
    http://www.importatlanta.com/forums/...1#post36366611
    Man thats retarted, dude should man up and get in touch with you. Sorry to hear that
    im thinkin rb's
    Beaufort SC
    Thats odd! i was the one that helped pull the motor. when we got the motor to my house, we cleaned it up. then we put a braker bar on the crank and it turned over a few times. after that we put it in my shed where it sat for a few months untill we put it in...
    he is not trying to rip you off to our knowledge it was a good motor...
    i vouch for NVMYSRT!
    Last edited by MongolPup; 01-30-2008 at 02:38 PM. Reason: Requested by thread starter
    Atlanta,GA/Tampa,FL
    How easily did it turnover with the breaker bar? It shouldn't take that much force to turn the crank anyways. You also have to understand what it looks like to me when he has seemingly started ignoring me. Everything was pointing to him being reasonable up until that point.
    im thinkin rb's
    Beaufort SC
    it turned over just fine. the car was sold as is, and the motor was pulled from a wrecked car that sat for a long time. and once we had the motor it sat for about 8 months. but it DID TURN OVER BEFORE WE PUT IT IN
    Last edited by MongolPup; 01-30-2008 at 02:39 PM. Reason: Requested by thread starter.
    pm sent
    Lexus GS300
    Quote Originally Posted by black95se
    What is your vouch worth? Nothing here.
    Rerun, I hope it works out for you. Hopefully that dumbass will pull his sack out of guts and let them dangle so he will know what it's like to be a man and own up. Later, QD.
    im thinkin rb's
    Beaufort SC
    what is anyones vouch on IA worth! NOTHING...
    there is nothing to man upto it was sold AS IS. he was given the run down on the motor...
    Atlanta,GA/Tampa,FL
    Quote Originally Posted by SL33P3R
    pm sent
    Replied.
    Thanks man.
    "As is" also means "as described". He told me several different times there was nothing wrong with the motor and that it would work fine. It doesn't work fine, and there is obviously something wrong with it. It cannot be turned by hand and the starter won't turn it either. Also, if there is nothing wrong with it why isn't he in here or pm'ing me back. That seems a bit off to me.
    LAWRENCEVILLE
    why are you positive the motors toast?? being that it was just "droped in" investigate why it wont turn over look for stuff like a bolt stuck in the flywheel. or a stuck starter. it might be something overlooked by both partys
    Hella stock member!
    Atlanta,GA/Tampa,FL
    The motor is coming out soon and I'm putting in a new one. Once it's out I'm probably going to take it apart and see exactly what the problem is. Myself and a couple other people have come to the conclusion that it is probably a bent rod or a dropped valve.
    LAWRENCEVILLE
    Quote Originally Posted by R3RUN
    thats cool i would try to pin point the problem before i went to all that trouble
    Hella stock member!
    There is a lot you need to learn little boy. If you were worth a shiit on here and anyone actually really knew you, you might have half a leg to stand on. But the fact that your little buddy has chosen to ignore this and not stand up for himself says a lot about character for him. Later, QD.
    Southside
    Currently Active Users Viewing This Thread: 4 (4 members and 0 guests)
    JDM_EK4, nvmysrt, black95se, dazn
    Apparently he's catching up on his reading
    SPEED HAX nvmysrt's Avatar
    Beaufort, SC
    Character? QD...you don't know me. I would have expected more out of some of your age. As far as the engine is concerned...i personally witnessed the car running prior to the wreck...Black95se and myself turned the motor over numerous times after we pulled it and before we installed it. Dose that mean it dosn't have a problem now, no. I did not intentionally try to screw anyone over. Thats not me. I'm also not the type of person to argue with someone over the internet like a bunch of 15 year old girls. BJ had an issue.....he called me, and left a message...I called him back, and he told me of the issue....i told him to keep me updated...never got another call.... The next day he demands money back via pm's. He never called me back after that nor had tried. Its a used car....SOLD AS IS. Plain and simple. He got my view on a refund....but being the nice and sincere fellow that I am...I HAD considered working something out with him...until threaten with legal action...I don't take kindly to that...not many ppl do. I am very sorry that things didn't work out as planed...I've been there...hell anybody in this industry surely has. Basicly BJ hasn't given everybody the 'full' story....but thats up to him....i'm not going to sit here arguing over what he's or what i said. I've said my peace and he knows where i stand now.
    2007-Magnetic Black 350z - JWT Popcharger, AAM test pipes*265whp/235wtq* SOLD
    Quote Originally Posted by nvmysrt
    We're not married or related so you don't need to expect anything from me. At any age.
    It's not now.
    You're right on that point. BUT, it is also sold as described. It isn't as it was described. If it isn't working, you have a moral obligation to fix it. If not, you're a trick.
    No you're not. If you were, you wouldn't be with this attitude.
    Well if my character was being trashed here and I thought I was right, I'd certainly try to keep it intact. But since you're standing now, you might want to pull your dress down. Your slip is showing. Later, QD.
    Beaufort, SC
    It's not now.
    your post is the exact reason i don't get into pissing contests on the internet...there's no tone of voice...theres no expression to be seen. you obvisouly are the type of person who thrives on interent drama. you have shown that time and time again....btw the 'as described defense'....the car was described as a rolling chassis and did not run. nowhere did it say that the car had a sound engine or running engine in the description. After being installed I didn't think to occsionally turn the engine over to be sure it would 'lock up'. QD...there is not a beef between us....this is between Bj and I...I do however admire you concern for a fellow enthusiest and local forum member.
    Why? Because you don't like being slapped by the long arm of logic?
    No. What I have "shown time and time again" is the fact that I hate stupidity and stupid people.
    But is it true that you listed that it only needed a couple of parts to make it run? That's where YOU fucced up. You should never had included that line. You should have left it at AS IS and that you don't know the shape of the engine or if it runs.
    I don't think there is beef between us either. I just don't like seeing someone get shafted. Later, QD.
    Atlanta,GA/Tampa,FL
    My next statement is being made directly to you via pm.
    Unfortunatly though there is no legal actions that can be made. If you have a bill of sale and he does that says the car was sold as is w/ no warantys expressed or implied there is no LEGAL action that can be done. Moral yes, legal no. When I sold my corolla the kid blew up the engine before he got home with it. Did I give him anything, yeah I told him not to worry about the 100 dollars he owed me. I only did that because I knew there was no way I was ever going to see the money, that and he was spinning tires out of my neighborhood and was generally beating the **** out of the car. For future reference assume if the person says the motor worked and it doesnt currently assume its not going to work.
    white power!!!!!! .....1
    That's why I specifically said "moral obligation." Lolol. Later, QD.
    Beaufort, SC
    Nismo I agree... QD I'm a man of my word bj has my offer... I'm not here to rip anyone off. What happens from here is up to him.
    Cool enough. Later, QD.
    do it sideways SicK SilViA's Avatar
    mcdonough
    craziness!!!i say nvmysrt it right but this is none of my business!!!
    94 honda integra
    90 240sx hatch(sold)
    92 240sx coupe(traded)
    93 e36 sedan (traded)
    89 240sx coupe
    Public Enemy #1
    actually there can be small claims legal action. Like QD said, BECAUSE nvmysrt said that ALL it need to run was ****,******,******** then that is not really being sold as is. But seeing as how the motor is bad, and that it needs more than specified he can get him in small claims court. But only with a bill of sale!
    other than that i was just following up the thread to see if the problem was resolved!
    Atlanta,GA/Tampa,FL
    We are currently in the stages of working this out. I will update my first post if and when we reach an agreement.
    If it works out, big ups to both you. Later, QD.
    Beaufort, SC
    I hope everything works out myself....
    Beaufort, SC
    I'm here to make friends and connections, not cheat anyone.
    Public Enemy #1
    well if this get works out let me now so i can close the thread for both partys!
    The Deep South
    if nvmysrt was going to cheat anyone he woould not have gone on here and try to defend himself he would have just gone mia. hope it works out
    Atlanta,GA/Tampa,FL
    I think we are close to getting this taken care of. Hopefully some updates soon.
    Beaufort, SC
    this issue has basicly been taken care of...i'm not a crook!! ROFL!!!
    Atlanta,GA/Tampa,FL
    As soon as its final I'll be making some changes to this thread.
    Beaufort, SC
    the issue is officaly settled.
    Atlanta,GA/Tampa,FL
    Check my first post for final updates.
    x2
    Wow is all I can say BJ. The reasoning skills and ass backward logic in this thread is ridiculous.
    Are you serious? When you incorrectly describe something, you are liable. If he said I dont know if the motor will run, he has no liability, but when he assures you that it will run and it doesn't there is clearly a problem.
    ***Lotus Elise***
    BlackWatchRacing
