Results 1 to 3 of 3
Thread: This is interesting!
    Emergency Medical Tech
    Oct 2003
    Duluth,Ga
    Default This is interesting!
    How Fit Are You?
    Take the Special Ops Challenge to see how fit you are
    By: Adam Campbell Men's Health
    More on this in Health & Fitness
    Even if you're not ready to sign up, it helps to be fighting fit. Test yourself against Ranger standards, using their recommended scores in pushups, situps, chinups, and a 2-mile run. Fall below the curve? Follow the accompanying training techniques from Michael Mejia, C.S.C.S., author of the Special Ops Workout. Do each 2 or 3 days a week, resting at least a day between sessions.
    PUSHUPS
    The Ranger goal: 80 in 2 minutes
    If you don't measure up: Do as many pushups as you can, then rest for 20 seconds. Repeat this back-and-forth process (work, rest) for 2 minutes. Keep track of the total number of pushups you perform in that time period, and try to beat it in your next workout.
    SITUPS
    If you don't measure up: Without resting, do as many situps as you can, timing yourself from start to finish. Then rest for that same amount of time. Repeat four times, always resting for only as long as it took to do your previous set. Work your way to the 2-minute goal.
    CHINUPS
    The Ranger goal: 12 or more
    If you don't measure up: Take the most chinups you can do at one time, and divide that number in half. Now perform sets of that number of repetitions — resting 60 seconds after each set — until you've done at least 12 chinups. (If you can do six chinups, you'll perform four sets of three repetitions.) Each workout, reduce your rest between sets by 5 seconds, until you're down to zero rest and able to do 12 consecutive chinups.
    2-MILE RUN
    The Ranger goal: 13 minutes or less
    If you don't measure up: Break the 2-mile distance into 440-yard increments (1/4 mile, or once around the track) and do eight intervals, running each in 1 minute, 38 seconds — a pace that's equivalent to a 6:30 mile — and resting for 60 seconds after each. Each workout, reduce your rest period by 5 to 10 seconds until you can do all eight 440-yard rounds without stopping.
    Provided by Men's Health
    You don't know how STRONG you are until being strong is the only
    CHOICE you have!
    'Born Ready!',LJ
    Duluth, GA
    Everything but the the run is no problem. That shouldn't take but a few weeks of running to get back to that level.
    Oct 2003
    Duluth,Ga
    Quote Originally Posted by NEONRACER
    Hell yeah...
    I can only do it for 1 1/2 miles...2miles are too damn much!
    CHOICE you have!
    'Born Ready!',LJ
