Results 1 to 4 of 4
Thread: Taurus Millenium Pro .40 Question
    IS300 NEMO's Avatar
    We Fuckin...
    Default Taurus Millenium Pro .40 Question
    Ok so I bought a taurus millenium pro .40 couple months ago. When I put 10 rounds into either clip(that came with pristol) it sounds like one of the rounds are loose inside the clip. Like something inside the clip is rattling. Take one of the rounds out and problem goes away. Just seeing if anyone else with the taurus millenium pro .40 has the same problem. A friend of mine has the taurus millenium pro 9mm and his clips hold 12 rounds and doesnt have this problem.
    Don Mon SiRed94's Avatar
    Morrow 30260
    This is pretty common with double stack magazines. As long as the magazine doesn't give you any feeding issues, it's nothing to worry about. It is usually just slack between two of the lower rounds in the magazine. Mostly it's because the angle of the ramp on the follower isn't the exact same angle as the feed lips, so the upper rounds are angled a certain degree and the very bottom round is angled another degree, so there is usually some slack towards the front of the round.
    IS300 NEMO's Avatar
    We Fuckin...
    Quote Originally Posted by SiRed94 View Post
    thanks for the info
    Senior Member EJdm's Avatar
    i have the same gun same problem...shoot about almost 1k rd and not a single problem...
    "Arriving at one goal is the starting point to another." – John Dewey
