Results 1 to 7 of 7
Thread: someone w/ an h22 and p13 please help!!!
    I shave my legs... dartingd's Avatar
    on the bike
    Default someone w/ an h22 and p13 please help!!!
    if anyone can, will you please meet up w/ me somewhere and let me plug ur p13 into my h22a to see if my ecu is bad? i'm not throwing a code, but vtec isn't engaging and i've checked most of the things to fix it, and all are clear...any help w/ this will be much appreciated!!!!
    PSN SN= dartingd
    RUTSPEED / Boobies ! RutRoe's Avatar
    Peachtree City Area
    I'm not insulting your intelligence... but check your oil level too.
    I forgot once and mine was a little low and vtec wont kick in unless it has teh right amount of oil for oil pressure...
    If everything else is fine I'd guess it was the Vtec solenoid before it was the ecu.
    Good luck man.,
    BooB CreW What ?
    One of IA's Awesome Mod's
    NASCAR on SPEED's Fun Guy
    HOST, Top Gear USA on History Channel starting late this Nov./Dec.
    YALL WANNA SEE MY FACE!!! 3gLudeH22a's Avatar
    Apr 2003
    dixie flag land
    Quote Originally Posted by tehpr3chr
    Is your VSS hooked up/working properly?
    Somtimes the little oil filter screen thats on the vtec solenoid or pressure switch gets dirty.
    Is your TPS working properly? When you get on it does it seem like you just hit fuel cut?
    What have you checked so far?
    Jan 2005
    Columbus, Ga
    Quote Originally Posted by RutRoe
    Good luck man.,
    now that you mention somethin like that ( dont mean to hijack the thread) but if your oil pressure is low and oil is low....like does that cause you have problems with engaging in first gear....cause my car felt like it was strugglin...you kno like when you shift and you rrpm is too low....i dont know whats up with that...never happened before and it doesn't always happen
    i know you love my swagger
    OG Black Delegation member
    RIP My Homie Elliot Sloan
    on the bike
    just did the swap, so i know oil isn't low, but i'll check it again to make sure...check solenoid, and the screen looked new almost...haven't checked the tps yet...the car doesn't like cranking in the morning, or when i get off work, and runs rich bad...i'm only gettin like 14mpg right now...i'd have it looked at, but i've already spent like 4200 on this swap total, so i'm flat broke...
    PSN SN= dartingd
    England's crunkest Sledlude's Avatar
    bottom of a whiskey bottle
    i had this same problem too with my h22... it was throwing an oil pressure valve code or some shit like that i dont remember exactly.. but it turned out not to be the ecu.. the vtec would not engage and the check engine light would come on if i revved too high before the engine was warmed up
    ______________________________
    i live my life one license suspension at a time-- and for that 6 months or more, i still drive.
    "It is clear our nation is reliant upon big foreign oil. More and more of our imports come from overseas." -George W. Bush
    on the bike
    no check engine light here tho....
    PSN SN= dartingd
