Results 1 to 24 of 24
Thread: Importatlanta is gay
    IA Freshman Member
    gwinnett
    Default Importatlanta is gay
    and qd is a flaming homo
    and yet you still are on here...
    and did i miss something that QD said or is everyone just decide ou of no where there going to start calling him out?
    R A W! x Resilience's Avatar
    Atl
    You niggas know my pyroclastic flow, its R A W!
    - Current: E36
    Gwinnett-Grayson
    wtf??
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    i say an ae
    you go die in a fire!
    kangarooster meadows
    Just because you're a cawksucker doesn't mean the rest of us are.
    Stang Mod slostang's Avatar
    Southside
    IBTL
    cool thread man
    Daytona Beach
    Gingivitis
    ("inflammation of the gums") (gingiva) around the teeth is a general term for gingival diseases affecting the gingiva (gums)[1]. As generally used, the term gingivitis refers to gingival inflammation induced by bacterial biofilms (also called plaque) adherent to tooth surfaces.
    Contents
    [hide]
    * 1 Causes
    * 2 Symptoms
    * 3 Prevention
    * 4 Diagnosis
    * 5 Treatment
    * 6 Complications
    * 7 References
    * 8 External links
    [edit] Causes
    Gingivitis is an irritation of the gums. It is usually caused by bacterial plaque that accumulates in the small gaps between the gums and the teeth and by calculus (tartar) that forms on the teeth. These accumulations may be tiny, even microscopic, but the bacteria in them produce foreign chemicals and toxins that cause inflammation of the gums around the teeth. This inflammation can, over the years, cause deep pockets between the teeth and gums and loss of bone around teeth—an effect otherwise known as periodontitis.
    Since the bone in the jaws holds the teeth into the jaws, the loss of bone can cause teeth over the years to become loose and eventually to fall out or need to be extracted because of acute infection. Regular cleanings (correctly termed periodontal debridement, scaling or root planing) below the gum line, best accomplished professionally by a dental hygienist or dentist, disrupt this plaque biofilm and remove plaque retentive calculus (tartar) to help prevent inflammation. Once cleaned, plaque will begin to grow on the teeth within hours. However, it takes approximately 3 months for the pathogenic type of bacteria (typically gram negative anaerobes and spirochetes) to grow back into the deep pockets and restart the inflammatory process. Calculus (tartar) may start to reform within 24 hours. Ideally, scientific studies show that all people with deep periodontal pockets (greater than 5mm) should have the pockets between their teeth and gums cleaned by a dental hygienist or dentist every 3–4 months.
    People with a healthy periodontium (gums, bone and ligament) or people with gingivitis only require periodontal debridement every 6 months. However, many dental professionals only recommend periodontal debridement (cleanings) every 6 months, because this has been the standard advice for decades, and because the benefits of regular periodontal debridement (cleanings) are too subtle for many patients to notice without regular education from the dental hygienist or dentist. If the inflammation in the gums becomes especially well-developed, it can invade the gums and allow tiny amounts of bacteria and bacterial toxins to enter the bloodstream. The patient may not be able to notice this, but studies suggest this can result in a generalized increase in inflammation in the body and/or cause possible long term heart problems. Periodontitis has also been linked to diabetes, arteriosclerosis, osteoporosis, pancreatic cancer and pre-term low birth weight babies.[citation needed]
    Sometimes, the inflammation of the gingiva can suddenly amplify, such as to cause a disease called Acute Necrotizing Ulcerative Gingitivitis (ANUG), otherwise known as "trench mouth." The aetiology of ANUG is the overgrowth of a particular type of pathogenic bacteria (fusiform-spirochete variety) but risk factors such as stress, poor nutrition and a compromised immune system can exacerbate the infection. This results in the breath being extremely bad-smelling, and the gums feeling considerable pain and degeneration of the periodontium rapidly occurs. This can be successfully treated with a 1-week course of Metronidazole antibiotic, followed by a deep cleaning of the gums by a dental hygienist or dentist and reduction of risk factors such as stress.
    When the teeth are not cleaned properly by regular brushing and flossing, bacterial plaque accumulates, and becomes mineralized by calcium and other minerals in the saliva transforming it into a hard material called calculus (tartar) which harbors bacteria and irritates the gingiva (gums). Also, as the bacterial plaque biofilm becomes thicker this creates an anoxygenic environment which allows more pathogenic bacteria to flourish and release toxins and cause gingival inflammation. Alternatively, excessive injury to the gums caused by very vigorous brushing may lead to recession, inflammation and infection. Pregnancy, uncontrolled diabetes mellitus and the onset of puberty increase the risk of gingivitis, due to hormonal changes that may increase the susceptibility of the gums or alter the composition of the dentogingival microflora.[citation needed] The risk of gingivitis is increased by misaligned teeth, the rough edges of fillings, and ill fitting or unclean dentures, bridges, and crowns. This is due to their plaque retentive properties. The drug phenytoin, birth control pills, and ingestion of heavy metals such as lead and bismuth may also cause gingivitis.[citation needed]
    The sudden onset of gingivitis in a normal, healthy person should be considered an alert to the possibility of an underlying viral aetiology,[citation needed] although most systemically healthy individuals have gingivitis in some area of their mouth, usually due to inadequate brushing and flossing.
    [edit] Symptoms
    The symptoms of gingivitis are as follows:[citation needed]
    * Swollen gums
    * Mouth sores
    * Bright-red, or purple gums
    * Shiny gums
    * Swollen gums that emit puss
    * Severe oral odor
    * Gums that are painless, except when pressure is applied
    * Gums that bleed easily, even with gentle brushing, and especially when flossing.
    * Gums that itch with varying degrees of severity
    [edit] Prevention
    Gingivitis can be prevented through regular oral hygiene that includes daily brushing and flossing. Mouth wash is optional, usually using a saline solution (water and salt) or chlorhexidine. Rigorous plaque control programs along with periodontal scaling and curettage also have proved to be helpful.
    Researchers analyzed government data on calcium consumption and periodontal disease indicators in nearly 13,000 people representing U.S. adults. They found that men and women who had calcium intakes of fewer than 500 milligrams, or about half the recommended dietary allowance, were almost twice as likely to have gum disease, as measured by the loss of attachment of the gums from the teeth. The association was particularly evident for people in their 20s and 30s.[citation needed]
    Research says the relationship between calcium and gum disease is likely due to calcium’s role in building density in the alveolar bone that supports the teeth.[citation needed]
    [edit] Diagnosis
    It is recommended that a dental hygienist or dentist be seen after the signs of gingivitis appear. A dental hygienist or dentist will check for the symptoms of gingivitis, and may also examine the amount of plaque in the oral cavity. A dental hygienist or dentist will also look for signs of periodontitis using X-rays or periodontal probing as well as other methods.
    Hypervitaminosis A, otherwise known as excess Vitamin A in the diet, has also been linked to gingivitis in cats and dogs.[citation needed] Whether this is applicable to humans remains unclear.
    If gingivitis is not responsive to treatment, referral to a periodontist (a specialist in diseases of the gingiva and bone around teeth and dental implants) for further treatment may be necessary.
    Treatment
    A dentist or dental hygienist will perform a thorough cleaning of the teeth and gums; following this, persistent oral hygiene is necessary. The removal of plaque is usually not painful, and the inflammation of the gums should be gone between one and two weeks. A gargling of brine water also helps. Oral hygiene including proper brushing and flossing is required to prevent the recurrence of gingivitis. Anti-bacterial rinses or mouthwash, in particular chlorhexidine digluconate 0.2% solution, may reduce the swelling and local mouth gels which are usually antiseptic and anaesthetic can also help. For serious cases, dentists can oversee special treatments that allow medication to be maintained around the teeth and in the sulcus long enough to kill gingivitis causing bacteria via non-invasive devices known as Perio Trays.
    Gwinnett-Grayson
    lol wtf ej
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    NW ATL
    ...oh look, another noob trying to call QD out. *yawn*
    Gwinnett-Grayson
    lol same shiz diff day right lol.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Stone Mountain
    callin out QD should be grounds for banstick
    NW ATL
    true story.
    edit - that was to blacknightteg, not the rep-fisher.
    F yeah its gay. White power!
    white power!!!!!! .....1
    Dunwoody
    Syphilis
    From Wikipedia, the free encyclopedia
    Syphilis
    Classification and external resources
    Image of spiral-shaped organisms responsible for causing syphilis
    ICD-10 A50.-A53.
    ICD-9 090-097
    MedlinePlus 001327
    eMedicine med/2224 emerg/563 derm/413
    Syphilis is a sexually transmitted disease caused by the spirochetal bacterium Treponema pallidum pallidum. The route of transmission of syphilis is almost always through sexual contact, although there are examples of congenital syphilis via transmission from mother to child in utero. The signs and symptoms of syphilis are numerous; before the advent of serological testing, precise diagnosis was very difficult. In fact, the disease was dubbed the "Great Imitator" because it was often confused with other diseases, particularly in its tertiary stage. Syphilis can generally be treated with antibiotics, including penicillin. The oldest and still most effective method is an intramuscular injection of benzathine penicillin. If left untreated, syphilis can damage the heart, aorta, brain, eyes, and bones. In some cases these effects can be fatal. In 1998, the complete genetic sequence of T. pallidum was published, which may aid understanding of the pathogenesis of syphilis.
    North Augusta, SC
    awww, someone got neg repped and now he is butt hurt.
    Back to being stock and slow
    Gwinnett-Grayson
    haha its ok, i got neg repped earlier too lol. gah lol it just made my e-self esteem go down so low haha.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    right behind you...
    dumbass noobs ftl
    North Augusta, SC
    dumbass noobs ftl
    lol... ah, who am I kidding... I'm a noob and I still agree with this statement. lol
    You need HD 2 see me
    Mall of GA/L-Ville > Fort Hood, TX
    Quote Originally Posted by peter411
    and its capital q , capital d... ie. QD.......... Go join the BANwagon noob....
    right behind you...
    Quote Originally Posted by Motivation
    lol, reps
    Quote Originally Posted by x Resilience
    lol @ link...i hate that...i dont know what im tom bout...oh yea plies..i hate him
