Results 1 to 5 of 5
Thread: 2005 GG MR Evolution Built $16,900
    IA Member mugen777's Avatar
    Default 2005 GG MR Evolution Built $16,900
    2005 GG Mr (shep 5spd Transmission)
    80k Miles
    Clear Title
    Chattanooga, TN
    423-650-8349
    Need the car gone to free up money for a house.
    Price Drop:$16,900.. Killer deal on this car.
    VIDEOS
    Walk around added 04/29/12
    I've got other videos on my YouTube account including some pulls
    http://www.youtube.com/watch?v=AXEjjrkyFeo
    http://www.youtube.com/watch?v=_JmbLaM5fxk
    http://www.youtube.com/watch?v=QGjvAtnA0gw
    I am lowering the price to $16,900 because im getting lots of requests to put the AC back in and to install the heater core.... I don't have time to do this nor do I wanna spend any more cash on the car at the moment. So a $600.00 price drop should cover the expenses related to have these installed. Thanks!!
    I am the third owner of the car. Some of you may have seen it for sale before. Ive had it up before but decided to keep the car but
    this time its for sure. I am an honest seller and will tell every detail I possibly can. I have over $20,000 in parts and labor into the car. I think my price is extremely fair and it should move quick. Its priced the way it is because its not perfect but all the imperfections are primarily cosmetic.
    The Ugly:
    The carbon fiber hood and trunk look like crap, it probably looks fine to some but it just fading and cracking (needs some work)
    Paint is still extremly glossy but has a few small nicks and or dings which is to be expected.
    Driver Seat on the back part of the plastic cracked from a friend accidently kicking it.
    Missing Front lip/spoiler cracked the carbon one I had before.
    Car was rubbing bad on the old wheel/tire combo and up in the rear fenders it was rubbing bad enough it rubbed paint off guess it just happened over time... (you cant see the rubbing unless you get on the ground and look up in the rear fender wheel)
    Don't get me wrong here the car is still very clean and in great shape but I am very particular and these are things I feel the potential buyer needs to know. {thumbup}
    The Bad:
    Removed AC .. I still have the entire AC system I will be giving to the buyer.
    Heater Core needs to be replaced, one of the lines busted and was leaking coolant. I have a new heater core just needs to be installed as of now I just have the heater core bypassed so it's not leaking.
    Now onto the good stuff:
    Car is currently sitting on wastegate pressure at 22-23psi pulls very hard. It made 508awhp on wastegate pressure before the cams, headwork, or intake manifold work. 600awhp on pump should be easy it just needs more fuel. It was tuned by Doug At TopSpeed. I also have tons of receipts for parts etc...
    First up the parts/modifications.
    Built By AMH Racing in Georgia
    Everything has 5k miles or under on it.
    Bottom End:
    Built 2.0L (rotated and balanced and all the other necesity machine work)
    Eagle Crank
    Wiseco 9.3:1
    Eagle Rods
    Cosworth Bearings All Around
    ARP L19 Studs
    Arp Mains
    Cosworth Head Gasket
    STM Oil Cooler
    (new oil pump, water belt, tensioner, belts etc etc)
    Cylinder Head:
    Crower 280's
    Fidanza Gears
    Gates Belt
    Fully Ported and Polished (local guy does awesome work and has done several 4g63 Motors)
    5 Angle Valve Job
    MAP 1.0mm Over Valves nitrate coated
    GSC Beehive Springs
    GSC Titanium Retainers
    GSC Chromoly spring seats
    Supertech Intake/Exhaust Guides
    Supertech Seals
    Stock Lifters
    Harley Davidson Crinkle Black coated valve cover
    Drivetrain:
    Shep 5spd Tranny
    Replaced ACD T-Case (had death whine)
    Exedy Triple Disc Clutch
    Torque Solution Billet front and rear motor mounts
    Torque Solutions Underhood Bushings
    STM Stainless one piece clutch line
    New slave and master clutch cylinders
    Fuel:
    RC 1000's
    Rewired 255 Walboro
    Intake:
    Custom Intake Pipe
    Ported Stock Intake Manifold
    JMF 3" UICP
    Custom LICP
    Tial 50mm Bov
    ETS 3" intercooler
    T-Bolts All Around
    Exhaust/Turbo:
    PT6765 Billet .82 JB
    Custom Tubular Manifold (started life as an Ebay manifold but has been rewleded and braced and works great)
    3" Full Turbo Back
    Suspension/tires/wheels:
    Stock Enkeis
    Nitto 555r Street Tire 2k miles on them
    Factory Billsteins
    Hotchkis Springs (installed 4/29/12)
    Electronics/interior:
    ETS Small Battery Kit
    SSL Seat Swap
    Pro Sport Boost Gauge
    AEM Wideband
    Autometer Oil Pressure
    Stock ECU Tuned
    __________________________________________________ ______
    Here are the pics of said blemishes:
    Driver side rear fender from previous wheel/ tire setup(rubbing):
    Trunk Needs to be recleared bad
    Hood is still glossy but still can see haze/scratchy spots again probably needs a good reclear.
    Passenger side rear fender from previous wheel/tire setup
    (rubbing):
    Knicks on driver side:
    Above driver side door....this was here when I bought the car not really sure what the cause was
    Passenger side below door
    Driver side seat
    99gsx eclipse sold!
    05 Evo VIII w/custom gt35r kit!! SOLD
    May 2010
    South Side
    suweeeet evo! GLWS.
    Stay Humble
    WV
    Damn.
    Thanks guys, finally got my VDR up on my laptop and the car is making 548awhp like it sits... the fuel system is maxed on pump gas at 25psi. This VDR is extremely accurate... I used it on the dyno and the numbers were within 1-2whp from the dynojet. Also I started the pull a bit late as you can tell....revved out to 8800 still being very conservative
    99gsx eclipse sold!
    MCD
    had a day set up with him and he never replied when it was time to meet up or anything. called this guy and text him with no response. no respose at all for a week. beware!
