Results 1 to 3 of 3
Thread: 1992, Turbo Civic Hatch, SI, 12,500
    IA Member Spacenutz's Avatar
    Bonaire, Ga
    Default 1992, Turbo Civic Hatch SI ,630HP, 11,500
    Let me start by saying this car is completely street legal. With that said, it also makes a difficult to drive daily driver. So if you are looking for a DD this isn't the droid you're looking for. If you are looking for a drag car to race in the Street Tuner class and win, this is your car. I've taken it to the track twice and never got to run the race tune. I ran 12.0 @ 18psi pump gas and I'm a terrible driver with only 5 passes under my belt.
    Makes 629 @26psi on VP110
    Everything built and fab’ed by James Emmino unless otherwise stated
    Block B18B1
    LS/VTEC
    GE Sleeved Block bored to 84mm
    10:1 JE 84mm Pistons
    JE Rods
    ACC Race Bearings
    New OEM water pump (5 Runs)
    Head B16
    Just had the head shaved (5 Runs)
    Hand port and polish by Turbo Dave
    GE Head Studs
    GSC Power-Division Turbo cams
    Skank 2 Cam gears
    Supertech titanium springs and retainers
    Supertech valves
    New GE LS/VTEC gasket (5 Runs)
    Transmission
    Competition twin disk clutch and flywheel
    Qualf LSD
    LS 5th, GSR 2nd and new OEM syncros
    B&M short shifter
    Turbo Stuff
    Precision 6262 w/ceramic coated hot side & Ebay Turbo Blanket
    Locash Racing Race Series Catch Can (Kit B - 10an fittings to screw into the back of the block)
    Custom aluminum intercooler piping
    AFI Top Mount Turbo Exhaust Manifold wrapped in DEI Titanium header wrap
    Blits blow off valve
    44mm Tial WG w/13# spring
    Electronics
    Hondata S300 tuned by Scotty @ Mainstream (93 Oct and VP110 Tune)
    Hondata Coil Pack Retrofit
    AEM Wideband
    2001 Honda Civic Coils
    Fuel
    Edlebrock Fuel rail
    Edlebrock Victor X Intake Manifold
    ID 1000 injectors
    Bosch 044 Inline Fuel Pump
    T1 Bosch 044 Inline install kit
    AEM fuel Regulator
    Walboro 255 Tank pump
    Suspension
    K Sport coilovers (new shock absorbers in rear)
    Energy Suspension polyurethane bushings (front and rear)
    New control arms and ball joints the front
    New tie rod ends
    Wheels
    Set of Weld Magnum Import Drag Series w/24.5x9 MT Bias-Ply slicks
    ARP Wheel studs
    GSR front and rear calipers
    Motegi Wheels w/very fresh 205x45x16 Bfgoodrich G-Force Sport in the front and Koyo on the back
    Other Stuff
    Koyo Radiator
    Mishimoto Silicon radiator hoses
    Ceramic coated Distro w/Locash Racing Billet Distro Cap cover
    Hasport solid motor mounts
    New (3 month old) Die Hard Gold Battery
    Tuned on 93 oct up to 18psi and VP 110 @ 26psi making 629 fwhp
    I have a stack receipts on all work done
    Not considering parting at all.
    Don't expect a reply if you low ball.
    No joy rides, serious inquires only.
    Text, call or email me with any questions.
    asking price $11,500
    Phone number: 678.787.3963
    Email:[email protected]
    Attached Thumbnails Attached Thumbnails -20141129_132028-jpg   -20141129_132038-jpg   -20141129_132159-jpg   -20141129_132235-jpg   -20141129_132249-jpg
    -20141129_132345-jpg   -20141129_132410-jpg   -20141129_134530-jpg   -20141129_134609-jpg   -20141129_141354-1-jpg
    -red-civic-jpg   -import-showdown-2013-26-jpg
    Bonaire, Ga
    Bump
    Bonaire, Ga
    Price drop
Tags for this Thread
