Results 1 to 13 of 13
Thread: 1990 ef hatch mpfi swap help
    FREE BUJU StarBwoy's Avatar
    IDK
    Default 1990 ef hatch mpfi swap help
    i got a ef hatch that is dpfi and want it to be mpfi will the dash harness from a 1990-1991 ef sedan lx or ex work and plug up to a si ef motor harness and fit in my ef hatch
    list of stuff i have
    si dizzy
    si harness
    si cluster
    si ecu
    and the mpfi motor
    do i need any more stuff
    need info asap
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
    Certified Gearhead dc2gs's Avatar
    Oct 2011
    cartersville
    You gonna convert the dpfi harness? I don't think the si harness will plug in. And the dash harness will need to be modified for it to fit. I think one of the plugs is different. I havent done this in a while so I may be wrong lol someone correct me if I'm wrong
    IDK
    need more info im goin to change out the whole dash and motor harness and put mpfi one in dash from a sedan ef ex or lx and a si ef motor harness
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
    You NEED to convert your stock engine harness. The Si/EX harness will be helpful to cut the plugs from. it will NOT plug into your car.
    IDK
    why. im taking out alllll the old harness wires and putting the new one in im confused i have all the si stuff the only thing that not si is the dash harness if i get a si dash harness will that work and plug up dont see why
    i have the motor mpfi
    ecu si
    dizzy si
    cluster si
    dash si
    dash harness dpfi
    motor harness si
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
    have fun and make it harder than it needs to be!
    Macon, GA
    you got the resistor box?
    Oct 2011
    cartersville
    Dude just mod the harness you already have, it will be a lot easier than replacing all the harnesses.
    Dahlonega
    IDK
    i already did the dpfi mpfi swap and didn't work checked all my wire and got a brand new dizzy it ran but wouldn't go over 4 grand then the next day it didn't give no spark so I'm want to put the whole si harness in it not hard i already put dash harness in before
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
    Dahlonega
    Quote Originally Posted by StarBwoy View Post
    then, you didn't do it right.
    not being a dick, but double check everything as you've obviously fucked something up...
    Newbie Photodude RBS's Avatar
    All Over U S A
    you should just pay someone who knows what their doing to do it for you, because apparently now you f*cked your car up LOL
    IDK
    Quote Originally Posted by RBS View Post
    ha ha well you come and check it out
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
