- Help! S2000 problems
Need help on this. My s2000 started smoking from the power outlet cord. Now it starts without the push start button an the radio does not work. I checked all the fuses and they were fine.
Also clutch engages right when I press clutch if I hold it all the way Down it makes a chatter noise
Probably a shorted wire, causing the smoke, and then a fuse to blow...
what kind of chatter noise?
It sounds like the starter. Im going to disconnect the clutch safety button anyone know how?
I unplugged a clip that was connected to the clutch an plugged it back in and the car runs back to normal. Radio still not working but I can do that myself. Thanks for the reply though emminodagreat.
I wouldnt drive without a fire extinguisher. Sounds like an electrical fire waiting to happen.
- You may not post replies
- You may not edit your posts
Forum Rules
