Thread: ef wiring problem. please help!!!
    IA Member 90_sedan's Avatar
    Aug 2009
    Clayton Co.
    Unhappy ef wiring problem. please help!!!
    i have a 1990 honda civic ex. i put a b18a1 in it about 2 and half months ago. just recently i lost power to my main relay and ecu. i tried putting a new relay in but did nothing. thats when i checked and found out no power is getting to the relay. the main fuse is brand new tho. the fuel pump is not kicking on and im not getting any spark. anyone have any ideas or willing to come check it out? i can pay you. i hate wiring. lol. im trying to get it goin for the show this weekend. thanks to all help.
    It's all about JDM.
    CA to GA
    Check all your fuses in the fuse box, to verify you don't have any blown fuses (if you do, change them with the correct amp fuse). Check the one under the hood and steering wheel dash. Make sure all your grounds are in tact and secured tightly to the body. AND first and foremost, use a voltmeter tester. Make sure you got power running through all your power lines.
    is the ignition switch outputting power to the relay? Does the feed side of the fuse have power? If not then get a wiring diagram and go to work.
    Aug 2009
    Clayton Co.
    can a bad ignition switch cause that? cause it is still turnin over. just no ecu.
    take it mitchwork they are good with wiring
    "PRIME SUSPECT"
    Aug 2009
    Clayton Co.
    well i got it to crank up today. i just woke up and thought i'd give it a try. drove it around the neighborhood. came home cut it off. now its doin the same thing again. i guess im goin to hitchike to the show. lol.
    **ef sedan b18a1 - TRADED
    **89 Si Hatch/soon to be b20 - DAILY
    EF'N dirtragz's Avatar
    Jul 2009
    the ham
    Quote Originally Posted by 90_sedan View Post
    thats life ,, full of disappointments
    88 crx hf lsvtec 153hp 117tq mainstream
    You always lose money chasin' hoes, but you never lose hoes chasin' money.
    Quote Originally Posted by Civichatch91 View Post
    I will never cheap out again...I should have known better
    Aug 2009
    Clayton Co.
    hahah. yep. i've come to find that out.
    Aug 2009
    Clayton Co.
    i got it fixed!!!! my dumb self pulled the wrong relay when i replaced it before. lol. i thught i pulled the main. if i only would've looked about 6 inches higher. thanks for all the help everyone.
