IA Member $189.99
You can record your hold day trip, Snap on
Snap off without any installation.
Brand New In the Market
Wide angle rear view mirror with digital video recorder and Bluetooth hands free car kit and GPS & G-sensor
Model Number
DVR-100D
DVR-100D is a wide angle rear view mirror with DVR, Bluetooth hands free car kit, GPS module and G-sensor. DVR module has high quality image sensor and lens to record image on SD card while driving.
Bluetooth hands free car kit can let drivers use cellular phone safely while driving.
Description:
DVR-100D is a wide angle rear view mirror with visible area of 300mm. Furthermore, it’s equipped with DVR module, which can start loop recording when vehicle engine is turned on. The DVR module has high quality image sensor and lens to record image with 640*480 resolutions at 25 fps. Moreover, it has built-in Lithium battery to serve as backup power such that the module can keep on recording for 10 seconds when vehicle power is shut down. Bluetooth hands free car kit is version 1.2 and effective range is 10m. It has auto connect function and can pair up to 7 slaves.
It also supports headset, hands free profile and voice dialing so the drivers can use cellular phone safely while driving.DVR-100D is equipped with G-sensor which can detect the intensity of impact and modify the attribute of file such that it cannot be overwritten.
GPS module can display the driving path on Google map for driver to track.
What are the Benefits?
* Ensure safety of driver and passenger
* Video, audio, speed, time & date, G-sensor data, GPS, Google map - evidence when accident occurs!
* Evidence in accident fraud case & reduce cost and save time on insurance claim process
* Monitor driving routes, speed and driving behavior
* Encourage safe driving with camera presence
* Helps your business fleet to reduce collision
Specifications:
Operating voltage: 12V
Visible area: 300 mm
Installation: Clip on. No need to remove original rear view mirror
St temperature: -30°C~+80°C
Op Temperature: -10°C~+50°C
Weight: 330g
Dimension: 315mm * 85mm * 21mm (Without clamp)
Image sensor: VGA1/4" CMOS
LCD monitor: AUO 2.4 inch(480*234)
Video format: MPEG 4 ASF
Video resolution: 640*480 at 25 fps
SDHC support: Up to 8GB
Battery: Built-in Lithium rechargeable battery
GPS: External
G-sensor: Built-in
Recording mode: Synchronized video and audio
Bluetooth Hand Free Car Kit
Bluetooth version: V1.2, class 2(QDID:B014086)
Effective distance: 10 m
Pairing: Up to 7 slaves
Profile supported: Headset and hands free profile
Op frequency: 2.402 to 2.480GHz unlicensed ISM band
Microphone and speaker: Built-in
Package Include:
*Digital Video Recorder
* DVR-100D with Built-in 4.75cm x 3.75 cm LCD Display
* FREE 4GB SDHC Memory Card Included
* DVR-100D Software
* Power Cable
