Results 1 to 10 of 10
Thread: help asap! please
    20BRX8 JayJones's Avatar
    McDonough, GA
    Default help asap! please
    does anyone have how to on installing a fuel filter for a 91 civic hatch?
    2 is always better than 1 hemi's Avatar
    Hiding from the Mob
    First take the old one off, then put the new one on...
    Here, hold my beer!
    your moms house
    lol its actually a rather easy job
    FUCK B&D COMMUNICATIONS!
    well see..you have to take apart the v-tec generator apart..then that wil lead you to the v-tec vortex flux-capictor ..which then will lead you to the fuel filter..but before you can remove the fuel filter you have light a cigg as you are removing it
    random guy's pops!
    random guy's moms cornhole!
    there is two bolts on the top of the filter , i believe one is 12mm and the other is a 17mm , and one 10mm bolt on the side that holds the filter there , dont remove the 10mm till you take off the two other bolts , make sure when you are takin off the bigger bolts you hold the lines firmly , make sure thatwhen you put the new one on the writin on the top faces the rear of the car , if you happen to not know where the filter is ...... it is on the passenger side firewall , it is a very easy install! oh before i forget , make sure that you have one copper o-ring on the top and the bottom of the bolt when you replace them , they should come with the new one , when you start the car , it wont start rite up! dont panic , it will fill up and start! hope this helps!
    dnwp
    my idea was better
    random guy's pops!
    your " " ideas are always better! lmao!
    dnwp
    PEENGONE Hektik's Avatar
    make sure to dry up th fuel lines before....
    take out the fuse for the fuel pump.start the car and let it idle for a couple of minutes at most and it should die on its own this will pull the fuel out of the lines this way you dont end up with fuel all over urself...
    make sure to put the fuse back in after u switch it out or the car wont start. an ur going to have to give it a couple of tries.
    random guy's pops!
    its ok noob , post a thread then not say thanx to the people who are helpin ya , or as a matter of fact post any kind of response! so......you get one of these from me
    dnwp
    His thankfull
