Page 2 of 2 FirstFirst 12
Results 41 to 48 of 48
Thread: Aight I have my header install...
  1. #41
    PEENGONE Hektik's Avatar
    Quote Originally Posted by ~The_Duke~
    Oh I am using the anti-fouler for an O2 sim (oops wrong wording)
    no what im talking bout is a little different. the anti-fouler works really good if u have the o2 plugs on ur exhaust, the sim is made for cars that have straight piping exhaust with no o2 bungs so they trick the ecu into thinking that there is an o2 there and that it is sending out a certain voltage..
  2. #42
    LNC FTW
    I'm up 'n Cummin'
    Quote Originally Posted by Hektik
    interesting...
    I am not sure how it works, but I would assume that it would be fairly easy to create some sort of chip that would connect up to the normal O2 sensor things that would spam a good reading over and over again...
    My YouTube Channel
    Make sure you "like" the videos purdy please.
  3. #43
    nonfoulers arent always reliable sometimes they work sometimes they dont, i installed a header in a Se-r (hopefully what your talking about) and it deleted the cat, mil light came on but went away on its own after a while... O2 simulator.com for the safe bet
  4. #44
    If the light won't stay off with 1 anti-fouler, add a 2nd one. If you use a long anti-fouler to start with and make the hole a close fit around the sensor probe it'll work better.
    To turn the light off, go into diagnostic mode with the pedal, let it cycle, then hold the pedal down for at least 10 seconds (just do 20-30 secs to be sure), then switch the ignition off. When you restart the car the light should be gone. The benefit to doing it this way is the fuel trims and ignition trims aren't reset, but after any mod it's good to reset the ECU and let it relearn fuel trims, because the air flow and whatnot is going to be slightly diffrent.
    Doing an idle relearn is almost the same as going into diagnostic mode, but that's next weeks "Your Spec V" lesson.
  5. #45
    LNC FTW
    I'm up 'n Cummin'
    So then what does unhooking the battery do then? lol
    My YouTube Channel
  6. #46
    it resets more than just the light.
  7. #47
    LNC FTW
    I'm up 'n Cummin'
    Yes it does, your radio presets, your clock, you trip odo...
    The anti-fouler trick worked like a charm
    BTW Big J I saw that the check I gave for the header cleared
    My YouTube Channel
  8. #48
    All the anti -fouler does is space the o2 so far back the air near the o2 is somewhat stagnant rather than having a sweeping a/f ratio reading that would indicate a failed cat.
