- Help! jdm gauge cluster?
- Rep Power
- 23
the jdm cluster will plug directly in.. I didn't think the dimmer however was attached to the cluster. The dimmer switch should be easily found in a junkyard.
The little dimmer switch for my gauges fried! the gauge cluster nor the climate control lights up. the switch is connected to the back of the cluster. I want to buy a jdm cluster but it doesn't come with the little box for the switch. does the jdm cluster have it built in? Also are all the wiring and plugs the same? for a usdm del sol cluster and a jdm del sol cluster? plz help
Society-ZERO-Member #7
don't know but dimmer switches aren't expensive and it's only three wires
no the switch is attached to the cluster
- You may not post replies
- You may not edit your posts
Forum Rules
