Results 1 to 15 of 15
Thread: Gauge Install (boost)
    Exclamation ...
    Shine on! Nittanys1's Avatar
    Raleigh, NC
    no need to post this twice............................
    georgia
    what kind of guage? if it has the little plastic line just run it to a vacume line and splice in a T fitting.you can buy a brass fitting and put brass nipples on each side of the splice and use the correct compression fitting on the boost guage line in the middle of the T,it should come with a compression fitting. ace,homedepot,or howard brothers have tons of fitting to choose from. the electrical is pretty easy too. run your ground(black wire) and your red to head light switch.i ran mine to the fuse box.find the head light fuse and splice into the wire behind the fuse box to the switch.all this worked for me with no trouble. hope this helps.
    yes i am....
    Exclamation
    Raleigh, NC
    battlgrounds should be able to
    What"s up vanilla face? Tracer's Avatar
    Batlground Engineering
    1770 Atlanta Rd.
    Smyrna, GA 30080 ph# 770-319-9605
    They can help you out with anything.
    Banned flysi00's Avatar
    why dont u just do it yourself
    or H&M motorsports or batlground
    -=Mi4=-
    got the $$ then take it to battleground. if u short then do it yourself. very cheap/quick. just ask any turbo guys you see on the street and they will most likely help/show you. based on what BD wrote on previous post that is about right.
    guages usually take about 1 hour
    Val for president!
    Facebook.com/TracyATL
    hookin up a boost gauge doesn't take long.. run the hose tho the firewall.. find a vacuum line.. cut it or find the end of it put the T fitting in and hook up the hose's... takes an hr if u dont have the gauge in its spot.. save your money take and hr and ask one the the turbo guys to point out the vacuum line they use... guessing turbo and supercharges are about the same... vacuum line wise all vacuum lines will show boost.
    Quote Originally Posted by Clipz99
    hey guys thank you all for your help. I actually installed it all myself this weekend. looks great. thanks again.
    -Joey
    Sweet! Glad it turned well out for u
    Val for president!
    Formerly Spyder Man
    Buford, Ga
    Quote Originally Posted by AeRo
    No they don't. some are on vaccume canisters or the back side of a one way valve.. there are alot of different ways vaccum line can be routed, also some are controlled by various things in the car such as idle control valves, water recirculator valves, and everything else. Also when tapping into some lines it can affect the smoothness of the way things operate ,for example the FPR will be screwy on some cars if you tap into its line. etc..
    I didnt mean all that to sound dick if it did but i just didnt want people to think it is as simple as tapping "any" vaccum line.
    :boobies:
