Results 1 to 19 of 19
Thread: PRELUDE CLUTCH CHANGE 4/29 --12:22 PM
    Oct 2003
    Exclamation PRELUDE CLUTCH CHANGE 4/29 --12:22 PM
    So i got this damn 97 Lude and when i got it the clutch was almost gone....well now its all gone...i can shift gears without having to clutch and it still doesnt move...
    But yea
    Well I got the damn axles out and the mounts off.......shit i'm thinking of taken the whole swap out to change out the clutch....Bseries is so much easier...more room i could pull the motor in and out in a few
    So should i take the motor& tranny out or take just the tranny out? Any tips ideas? Nvr done just a clutch change with motor/tranny in car
    lmk asap still taken off bolts right now
    if anythign i'll just hank the whole shit out
    I Sell Rubbers
    Roswell, GA
    i give this thread 5 min b4 its moved...lol
    Quote Originally Posted by Alpharetta Police
    Ask me why im looking at you...
    Aug 2001
    Charlotte, NC
    Quote Originally Posted by SwurvinIn
    You are correct....lol
    '15 Chevy SS
    '16 K7 SXL SWP
    Oct 2003
    Woops....lol it was suppose to be in the Tech Forum...someone move this
    Damn this tranny fluid seems that it hasnt been changed in 124,xxx miles
    I Sell Rubbers
    Roswell, GA
    Quote Originally Posted by annihilation
    ewwwwww.....be careful with that. hopefully it wont freeze w/ the new fluid
    There are actually several places this would be suitable in:
    GENERAL TECH
    HONDA. In the JAPANESE section.
    ALL MOTOR
    Lolol. Later, QD.
    stockbridge
    how do u know its all motor?
    Because there was no mention of turbo or SC. I'm sure if there was one in the near future, it would've been mentioned. Later, QD.
    Mas Puto! dELfONiK's Avatar
    I know your's is a 97, but there's a write-up for a 4th Gen with an H22 on Hondatech.. Here's the link.
    http://www.honda-tech.com/zerothread?id=907431
    Oct 2003
    Quote Originally Posted by dELfONiK
    Thanks for the Write up...its the same engine bay practically
    Boosted 4door
    the tranny should come right off w/out having to pull the motor..you might have to drop and raise the engine a little to get the stress off the input shaft, once all the bolts are loose from the bellhousing you should be able to pry it apart.
    on my accord i had to remove a piece from the suspension for some clearance to pull it out from under the car. im not sure if the 5th gen ludes have the bar that goes from the LCA to the front crossmember
    Oct 2003
    Yes it has the stablizer/radius arm on the lude as well...ok i'll try to tip it over and see wats good with it
    Thanks!
    DC5-R
    Gwinett
    since you took the axles and mounts out then just support the motor with a hydrolic jack with a block off wood and take off the bolts and drop the tranny on a tire or another hydrolic jack. But you're right, b-series are easier, took me 3 hours to do mines.
    Oct 2003
    Bitch ass this project sucked offically...
    Anyone know where i can find a machine shop open on a weekend? I NEED to resurface the flywheel
    murdahrin dem Blood-Claat!
    Quote Originally Posted by krucial7integra
    listen to this guy... thats the same damn thing I had to do. Also it took me about 8 hours and I was using my brothers transmission shop with all his tools. Damn Sh's
    good luck man!
    most local napas do flywheel resurfacing
    ... £G2♣'s Avatar
    2o9
    damnnn yo.......havent done these kinda work in the longest lol, and BTW oz (anihalation) how long did it take us to get the tranny off?
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    get the flywheel where im getting mines done... I'm sure i can add it into my order and hell be like give me an extra 30 bux or something LOL cuz im spending so damn much there
    Oct 2003
    Quote Originally Posted by RaИdomGuy
    umm it only cost $20 to get it turned
