Results 1 to 3 of 3
Thread: what consist of an engine build
    ALEX #1Beaver's Avatar
    Default what consist of an engine build
    like it says up top....
    i want to build for turbo and to finaly be able to rev high
    1......what do i need?
    2......what parts and what brand is better?
    3......oh and what tranny should i use?
    4......I have the LS tranny now can i keep that for boosting or should i go with a gsr?
    5......And can I buy LSD for a LS tranny?
    I have a bone stock 92-93 integra ls........B18a motor!
    In a EG Hatch
    if you want to Rev higher then you will need a vtec head or a Vtec motor...
    IMO the LS tranny sucks for anything except gas mileage go with the GSR but not a B16
    you dont really need to build an LS that much unless your gonna be running alot of boost..
    But if you want to build some stuff like non internals a diffrent Intake mani, up grade your Fuel system, and your ignition system would be a good start...
    But theres alot that can be built on a motor...just depends on how much you wnat to spend.
    known as Charles
    You need to figure out what you end goal is. What hp do you want? Is this a daily? Then you can figure out what you need.
    Also, you can rev a LS if you have the right parts. Stock LS's can't rev, built one's can.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
