Results 1 to 11 of 11
Thread: My car is bogging. Need help.
    The Thriller ghionw's Avatar
    Default My car is bogging. Need help.
    I have a 96 ek hatch. i swapped my stock intake mani for a d16y8 intake mani and I also put a short ram on it. In the mornings when it is cold and I drive the car, it bogs down sometimes. I need to know what causes this so that I can get it fixed... I would appreciate any advise because this is getting annoying.
    __DailyGrind
    Quote Originally Posted by ghionw
    >>>wat is boggin?...can u be more specific?
    Bogging - That is when the car suddenly either loses power or when the rpm suddenly drops for no apparent reason.
    I will try to think of a better way to explain it, but thats the best I got for now. I hope that helps.
    __DailyGrind
    did u change ur gasket?
    :noitacoL
    might not be gettin enough fuel.. check your fuel injectors
    Jan 2005
    Columbus, Ga
    lots of things, mainly could be fuel related, like uproot said, check your injectors, your fuel level, also, even check your spark plugs.....is it massive power loss, did it throw a CEL
    i know you love my swagger
    OG Black Delegation member
    RIP My Homie Elliot Sloan
    DC5-R
    Gwinett
    its the vacuum lines dude, when you swapped your IM did you change the IM gasket? did you put the vacuum lines back in the propper places? I just installed my skunk2 and had to "T" off some vacuum lines but thats what I think it is
    I did replace the IM gasket.
    It doesn't throw a CEL.
    I will have to check the injectors. I will probably swap back my y7 injectors into the y8 IM.
    To the best of my knowledge the vacuum lines are in their respective places.
    One of my biggest questions, is why would it happen mainly when it is cold out.
    I appreciate all your comments so far.
    Jan 2005
    Columbus, Ga
    well if it bogs, could be your timing belt or your cat convertor, mine bogged untill i replaced both those, especially when tryin to launch
    Wouldn't that throw a CEL code though. And it never did that before I swapped the Inatke Manifold
    Jan 2005
    Columbus, Ga
    hmm, i dun kno, its kind of tough to guess on it then, more then likely its somethin minor, i'd just double check all the lines, make sure there are no leaks and everything is on tight
